Updating via LVFS not working
Hi there!
I’ve got the 3.05 BIOS installed and I got the mail that 3.07 is ready out there, so I wanted to give a try to the LVFS install, but it did not work, here the output:
$ fwupdmgr refresh --force
Updating lvfs
Downloading…             [************************************** ]
Successfully downloaded new metadata: 2 local devices supported
$ fwupdmgr get-updates
Devices with no available firmware updates:
 • System Firmware
 • UEFI Device Firmware
 • WD BLACK SN770 500GB
Devices with the latest available firmware version:
 • Fingerprint Sensor
 • UEFI dbx
No updates available
$ fwupdmgr update
 • System Firmware
 • UEFI dbx
Should I go for the bootable-usb solution? why it did not work? battery state is at 90% aprox…
Ubuntu 24.04.1 LTS
Which release version?
Which kernel are you using?
6.1.0-1036-oem
3.05
13th Gen Intel® Core™
You could give enabling the testing repo a shot. AFAIK for 12th gen at least, they never resolved LVFS issues so updates weren’t available through there. Might be different for 13th gen.
You mean LVFS test? I could give this a try yes, but I never saw such option in any wiki or documentation page from the framework guys.
Thinking it twice, even it’s a nice to have, i prefer not to risk too muchon this topic :sweat_smile:
