Having upgraded to the 2.8K 120Hz display, I’m selling my 13.5" 2256x1504 60Hz matte display. The display is functional, might show some signs of use, but no scratches or dead pixels and the likes. One of the side metal strips is slightly bent. Please review the info & pics below and let me know if there are any questions.
Device: Framework Laptop 13
Included Parts: 13.5" 2256x1504 60Hz matte display with attached cable
Original Purchase Date: March 2024
Region/Country: US
Price (and accepted payment methods) : $70 (includes std. shipping)
Shipment option/shipment price: included in price, US-only
Yes, the display is available. AFAICT, the bent metal shouldn’t cause issues with installation because there’s a screw that goes into it which will hold it in place. You can also try to straighten it if you’re careful, but I don’t think that’s necessary (and might be risky as well).
Got the package and installed the display! Thanks for not scamming me The bent metal ended up being a bit of a problem. I had to bend it back to get the screws to line up. But I was able to without damaging the screen. Unfortunately the metal still pushes the screen out from behind when the laptop is open, and there’s a little bit of discoloration on the display as a result (it gets a little better when the display is forced flat, but there’s still a little washout where the metal is bent behind. But it closes with no problem, and I’m hoping that the more it’s closed, the metal will eventually bend back into position. Attaching pics so you can see.
Looks like I underestimated the effort that’d go into installing the display with the bent metal . I’m glad you got it working (for the most part). I’m mostly happy that the display found a new home instead of ending up as e-waste.
Haha, it’s generally safe transacting with people over the internet if they have been around their community long enough and have good reputation. I actually purchased my Ryzen AI 9 HX 370 board right on this forum! I have also had great success transacting on Reddit following the same principle.
Hello there!
I’m glad someone was able to buy it.
I got an address in Miami and I’m searching for this item again..
Please edit your post title as [SOLD]
