Thanks Ray, I have a gut feeling this is an AMD teething issue that an upcoming driver update for the FW16 will fix. Anything look amiss?
Summary
RX: MST 2lane HBR3 mode, EFM enabled, Lock sts: 00100030
Symbol error recently: 8000 8000 0000 0000, in 1s: 8000 8000 0000 0000
RFRM0: 0x0@4.96Hz RGB 6bpc, pixel clock: 0.0MHz, Audio disabled, state 1
HT: 0, VT: 0, HA: 0, VA: 0, HS: 0, VS: 0, HSW: 0, VSW: 0, HPOL: 0, VPOL: 0
TX0: HPD signal is low
RFRM1: 1920x1080@59.82Hz RGB 8bpc, pixel clock: 148.1MHz, Audio enabled, state 8
Audio: 2 channel 48.0KHz 16bits LPCM audio
HT: 2200, VT: 1125, HA: 1920, VA: 1080, HS: 192, VS: 41, HSW: 44, VSW: 5, HPOL: 0, VPOL: 0
TX1: 4lane RBR mode, EFM enabled, SSC disabled, output enabled
DPCD 202~205h: 77 77 81 03, symbol error recently: 8000 8000 8000 8000, in 1s: 8000 8000 8000 8000
RFRM2: 2560x1440@59.83Hz RGB 8bpc, pixel clock: 241.0MHz, Audio enabled, state 8
HT: 2720, VT: 1481, HA: 2560, VA: 1440, HS: 112, VS: 38, HSW: 32, VSW: 5, HPOL: 0, VPOL: 1
TX2: HPD ON, HDMI output, output enabled
2560x1440@59.82Hz RGB 8bpc, pixel clock: 241.0MHz, Audio enabled
RX VC slot info (FF means unused):
FF 02 02 02 02 02 02 02 02 02 02 02 02 02 02 02
02 02 02 02 02 02 02 02 02 02 02 02 02 02 01 01
01 01 01 01 01 01 01 01 01 01 01 01 01 01 01 01
FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
RFRM VCID list: 00 01 02 00
TX0 VC slot info (FF means unused):
TX0 VCID list: 00-00
TX1 VC slot info (FF means unused):
TX1 VCID list: 00-00
TX2 VC slot info (FF means unused):
TX2 VCID list: 00-00
