Hello,
After a night without use, my computer will not start without first being plugged into a power outlet.
I read on the forum that this is a sign of battery fatigue.
So:
- Can the 13th generation Intel laptop be used without a battery?
- If so, is it better to remove the battery now or wait until it dies?
- Is there anything specific I need to do to be able to use it without a battery?
Thank you.
Translated with DeepL.com (free version)
yes you can you can remove the battery from the laptop and use it without one or you can also replace it Battery Replacement Guide - Framework Guides
Can you $ upower -i $(upower -e | grep battery) while plugged in and with battery installed, to help identifying the battery issue?
Thank you both. I will ask my son how to answer your question, Charlie_6, because I don’t have the expertise, and I will get back to you as soon as possible.
I’m learning a lot
Firstly, that there is a command prompt and how to use it.
Secondly, that Charlie_6’s language doesn’t work on my computer.
And finally, that powercfg /batteryreport works for me.
So here’s the report, if I manage to attach it (fingers crossed)…
And no, I can’t figure out how to post the report here…
Is it possible to attach a file here, please?
After my son read it, the report says that the battery has 45,907/55,009 mWh, which is what it had at the beginning.
So it has lost 16% in 3 years.
So it is not yet at the end of its life.
So maybe it’s just the rechargeable RTC battery that is no longer acting as a starter.
I don’t mind plugging in my PC in the morning so it can start up, I was just worried about whether it could function without the main battery.
Question: can the computer function without the RTC battery?
Is it practical to charge the RTC battery using a bench power supply?
I don’t know how to do that Charlie_6, so I’ll buy another RTC battery, but I don’t like the idea of polluting
