I won’t be fully documenting everything here but I have QUITE a nice setup for labs/experiments here.
- I use debian 13 USERLAND
- I replace debian USERLAND with zabbix kernel
- I have a custom power script (basically it uses herustics if gpu goes up to 80% for more than 5 secnods we switch from ‘balanced’ to ‘perfomance’ It stays on performance for 300 seconds and then goes down. So my “MIN” power draw is 5 watts (gpu) and MAX can go upt platform madx (140 or so) in high performance scenaris.
- The hybrid kernel also loads the proper drivers for the NPU (you need to enable iommu)
- I load my ‘test’ models into LXC unprivilged containers with ‘mapping’ to enable local access
- I also have a zed container
- I use opencode as a harness
- I did use spensive (but free for a while) openai codex to build a lot of the studd.
- This hybrid setup gives me STABILITY of debian userpace with “RECENTNESS” of zabbix kernel
- Finally, I use the ‘whatever’ image to run vllm, (rarely), llama.cpp (various models mostly QWEN 36B MTP) MTP IS THE BOMB
- You can run qwen 27b dense, it follows directions well, but is like 3x slower, (sadness).
- I also have a ‘models’ mount point (read only) profile, an ‘internal’ containers network, and a ‘macvlan’ network option for local access (the machine itself can’t access macvlan, which is whny I have the 2 network profiles0.
- Incus has a nice ‘docker’ importer, so I just manufacture dockerfiles with my various lab experiments, and pull from the local repo.
- I do write MOST of my mcp’s in NIM (I made a nim MCP with a more advanced model so the ‘lesser’ models can actually code competently.
