Very high battery usage during suspend
Hi everyone, I am running the following system:
Fedora 41
6.12.15
3.04
Intel 13th Gen Core.
Basically, the issue is that I haven’t really used it for portability until now and I face a very big problem. The battery life during suspend is very bad. Like 30% battery usage over 7-8hours suspend and often if I leave it over a day the laptop dies easily. I wanted to know how can I fix this? Does the BIOS update fix this? I have seen recommendations of suspend-then-hibernate but I only have a 8gb swap(while I have 16gb ram) and I really don’t wanna waste time on that if the suspend issue can be fixed.
Please let me know. Thanks
I recall previously that this was an issue for some users of the AMD boards initially as well.
Forum member @Mario_Limonciello has mentioned a script that can run through things and check to see that all Linux toggles have been toggled appropriately for best suspend:
Hmm, on second thought, that might not be as useful here.
First remove all expansion cards to rule out USB issues.
yes, i have tested removing all expansion cards… similarly high usage
thanks yeah I don’t think an amd script will be useful for me…
Intel 13th gen has never had decent battery life, but just to be sure, do you have anything like the TLP tool enabled while PPD is enabled?
It’s an Intel you can use deep sleep to save energy. Add mem_sleep_default=deep to your kernel parameters
There have been lots of discussions and suggestions about this but nothing worked for me on my (older) intel CPU so in the end I set up hibernation instead:
Fedora 42
kernel: 6.15.7-200 32GB RAM
firmware: 3.08
Intel 13th Gen Core
Looks like about 10Watts after closing the lid.
cat /sys/power/mem_sleep shows: [s2idle] deep
After two hours of what I though was suspend to RAM, battery level went from 53 pct to 14 pct.
Ouch! I too am wondering how to get true S3 and suspend to RAM to save my session for more than a couple of hours.
