Viability of an ML 1220 rechargable battery for RTC | CMOS (11th gen)
I’m in the US and interested to see what the recommended modification is. I have managed to work around the issue but would prefer to have the RTC battery charge from the main battery as well.
I am unlikely to try to pull it off myself, more likely to see if I can ship the board to someone such as Louis Rossman to handle the work. It would be a bonus if Framework suggested shops that could handle the mod, but I think that that may be asking too much, as it (from my non-attorney perspective) might expose them to liability if the third party shop’s work were problematic.
I pulled out my 10 year old Dell from under the bed end of last week. Not used it since May of last year. It powered straight up. I too cannot see what the issue is, using a device you use for remote work, just on the occasions you work remotely and use a desktop machine when at home.
I’ve always been a Desktop at home and laptop on the go guy. Never rely on just one device! it might not fire up when you go to use it!
I’ll throw in my experience. After @BraneGenius said replacing the battery seemed to work I figured I try that.
The original battery was FDK so I bought one off Amazon (probably same listing as Brane mentioned). It arrived last Saturday so I swapped it in and did a full charge until Sunday. Took it off AC and packed it away until I had time to mess with it again. Was expecting I wouldn’t have time again until Friday.
Fast forward to today, a week later and later than I anticipated, it boots off AC and all the BIOS settings were retained. Prior to swap even with a full 24hr charge (amusingly I see now they are suggesting 48-72 hours on AC for a full reset) it wouldn’t last 2-3 days before failing.
This was literally the bare minimum I expected out of a portable tool and had been my only complaint. Now it could be usable in my case: as a non-work laptop (NOT workstation/desktop) that I primarily use weekend to weekend while on the go. Why it took so long to officially suggest swapping out the stock battery baffles me.
I’ll keep watching it and how it behaves but for those out there experiencing this because you too use this as a secondary AND portable machine, try a swap. It’ll cost some money but saves time over dealing with support and can’t be any worse than the stock battery
Sorry if I’ve misunderstood! It’s just that, in my adventures through the forums researching this issue, I’ve seen a common attitude among some posters that those experiencing this issue are somehow using their laptops irresponsibly. I’ve never known it to be an expectation that you need to charge a laptop literally every day, so these responses have seemed strange and not particularly constructive to me.
Sorry if this wasn’t how you meant it! :sweat_smile:
Speaking only for myself, I would absolutely not say that people are using their machines irresponsibly. Not at all. I do have two things to note, however.
First, I have non-Framework machines that will fire right up after sitting for a long time unused and off power. I also have non-Framework machines that will not boot up after sitting a long time off of power, until they are connected to a power source. So in my mind the issue, while I would prefer it not exist at all, is not Framework specific.
Second, the issue is entirely avoidable by setting a charge limit and leaving a rarely used machine connected to power. I know this because I have a second family machine that sits unused for long periods of time, and following that process has allowed it repeatedly to fire up with no problems.
So if anyone is experiencing the issue, no, they are not being irresponsible. They can however avoid the issue in the future by following the steps in my second point above. Finally, I am very much looking forward to being able to make the modification that will allow the RTC battery to charge from the main battery as well as from the power adapter.
Just my two cents. Enjoy the rest of the day.
Not a fix! That’s a work around. Devices do not like being hooked up to mains all the time even with a charge limit.
So no it is in no way avoiding the issue.
@Jason_Dagless - you are simply wrong.
First, I did not call it a fix.
Next, you are incorrect in your assertion that it does not avoid the issue. Leaving the device on mains unquestionably does avoid the issue of the RTC battery running down over time.
On the other hand, your comment about being connected to mains all the time is a reasonable one. Each individual must decide for himself or herself regarding that.
Whether you like it or not, leaving the device connected to mains avoids the issue of the RTC running down. It does NOT, however, address the root issue of the RTC running down. Even the modification for which we are waiting, allowing the RTC to be charged by the main battery as well as mains, just increases the time to run down. If one’s use case is such that the potential of the RTC running down over some period of time is a real one, then one must decide if the means by which to avoid encountering the issue is or is not reasonable.
Have a good day.
It’s a poor workaround that does not work for me. It’s an excuse for a mobile device with a battery…a whopping main one that just sits doing nothing while a piddly cell wears out in a few days.
No other laptop I have had in the past 20 years has had this issue. I would also point out that this is the most expensive laptop I’ve ever paid for with my own money.
I find it sadly ironic that this 11th generation of Framework “The Repairable Laptop” has a major fault that isn’t repairable.
Sad too.
@Jason_Dagless - sounds like it is not fit for your purpose, which is too bad, but understandable.
The RTC should not wear out in a few days, as has been pointed out to you upthread, so now one wonders if you are being disingenous to try to strengthen your case. To me, you weaken it. Support was clear that if the RTC battery is running down in a matter of days, that a ticket should be opened so that the battery can be replaced or the board replaced if the RTC holder is not allowing it to charge properly. So if yours is discharging in days that’s the path that you should take.
You find the workaround to be poor. Others may or may not.
I wish that it didn’t have the flaw, but it does work for my use case, even for the machine that I rarely use. As I noted, I have many laptops that don’t start after sitting off of power for a long time. That’s anecdotal, but so is your comment. It’s not a Framework-specific issue.
Be well.
@alowndar I’m really glad the swap has (so far) made a difference! Just a couple thoughts:
IMO it still might be worth contacting support. They were quickly willing to ship out a replacement ML1220 to me after the recent updates from the Framework team in this topic. I think, had I known about how the battery works all along, that the stock cell would have stayed healthy longer, and will probably be the best choice moving forward. Just my two cents.
I’m frustrated with this too. Having spent a lot of time reading, posting, and thinking about it, the conclusion I’ve come to is that it’s mostly a matter of Framework being a small company trying to do many things at once. The support staff seems pretty overwhelmed, so getting too mad will be like squeezing blood from a stone. It’s not an excuse, just a reality.
My hope in posting about it so much is just that Framework will do what they reasonably can for their early adopters. I still like the idea of the repairable laptop, find the device itself appealing in many ways, and want Framework to succeed. Even though it’s been slow, they seem to be listening and trying.
It’s something that happened first for me six or 8 months months ago (I hadnt used the laptop for a month) and just now happens more and more. The 11th Gen Framework laptop is just not physically/electrically suitable for my usage case. That is the issue.
Back then we were told by a few, it wasn’t an issue and to go away, then a few months later as more had the issue, Framework fessed up it was a problem. Oh and I did raise a ticket last June. It got a stock, you need to charge it answer.
*Thank you for your patience. Per a Community post by our Founder regarding RTC Battery functionality:
"The RTC battery (CMOS battery) powers the very low power subsystem that preserves the real time clock (responsible for providing the calendar clock to the system) and some processor state. This battery exists to allow system time to be preserved while the main battery is in ship mode, disconnected, or drained. The RTC battery recharges when the laptop is plugged into power.
Normally, when the RTC battery drains below the voltage threshold needed to power the RTC subsystem (if the laptop was left unplugged for months on the high end or weeks on the low end), the impact would be that the system clock resets. With most operating systems, this wouldn’t be noticeable, since the OS will automatically grab the current time off of a network time protocol server and update the system clock again. However, with 11th Gen Intel Core processors, Intel shared that there is a silicon bug where low voltage on the subsystem that the RTC battery powers can put the processor into a stuck state that needs to be manually reset (we wrote this guide to share the reset process: Fully Resetting the Mainboard State - Framework Guides 6 Note that allowing the RTC battery to fully recharge by keeping the system plugged in for >24 hours after a reset or after leaving the system unplugged for more than a few weeks is important). This happens randomly, in that only some instances of the RTC battery reaching low voltage will result in the CPU going into a bad state, which is both how Intel didn’t find this during development of the processor and neither we nor our manufacturing partner saw it occur during design of the laptop.
For folks on 11th Gen Mainboards, our guidance continues to be that if you plan to leave the laptop unplugged for weeks/months, to do so with power plugged in. If not, there is a some percent chance that the manual reset will be needed at the next time the laptop is used. We know that if this is a behavior you regularly need to follow, that it is annoying and decreases the enjoyment of using the product. Since this does occur randomly, it is possible there are processors or RTC batteries that it is more likely to occur on than others. If you are seeing this happen unusually often, reach out to Framework Support, and we will work with you to swap you out a replacement RTC battery or replacement 11th Gen Mainboard. There are possible mitigations we are investigating in firmware, like having the main battery “power up” to recharge the RTC battery when the system is unplugged for long periods of time, though over a long enough period, that would result in both the main and RTC battery being empty and still risking entry into the stuck state. This firmware mitigation is speculative though, so we don’t have a firm plan for it.
For the future, with 12th Gen Intel Core, there are a few changes that prevent this from occurring. We’ve reduced RTC battery power consumption to make the RTC rail stay powered for about twice as long with the system unplugged. We’ve also designed in a path that allows the main battery to keep the RTC battery charged. Finally, we’ve designed a reset circuit that prevents the manual reset process from being needed, doing an automatic process instead."
Swapping the mainboard would only be a valid option if the mainboard reset process is needed frequently even after trickle charging the RTC for 24 hours after non-use for weeks/months. If that’s happening, there’s a chance either the RTC battery is faulty or or the RTC battery holder might not have a solid connection to the mainboard. Outside of the above, a swap of the mainboard would not result in any meaningful change to observed functionality as it is expected.
Regards,
Framework Support"
At the end of the day, the only thing I’ve done ‘wrong’ is leave my £1200 laptop in my laptop bag for more than a week or two on occasion. That’s how I use my laptops. I don’t think that is outrageous in 2023.
There will be more with the problem. Give it a few more months. I’m surprised they are still selling the 11th Gen boards to be honest.
What battery did you buy exactly? Personally I am a bit afraid putting the wrong one in, probably I heard to many stories about exploding batteries.
@Jason_Dagless
No one is saying that you did anything wrong. You didn’t. I think that you know and are willfully dodging that you need to open another ticket now to get your current issue addressed - worn out RTC battery or board with a problem that causes the RTC not to charge properly. Given your use case my guess would be the former. Time will tell if more people hit the issue. Likely yes, but it remains to be seen if it is significant, or incremental.
I have a more than one expensive non-Framework laptop that will run down if I don’t keep it charged. I deal with it. To be clear, I’m not suggesting that you or anyone else should, merely noting that for some it may not be a show-stopper.
I hope that our back-and-forth has not been too pointed. I appreciate the vigorous debate, and do hope that you achieve resolution by whatever means.
I have indeed raised another ticket and bought a high quality VARTA ML1220 in case Framework have an issue shipping me one. Though looking at their suppliers I think the VARTA will be a better one.
And no it’s all okay, forums are poor for discussing things. Much better to be down the pub having a moan about it over a pint. :smiley:
As I mentioned I took note of the manufacturer on the stock battery my unit shipped with “FDK” and searched for it on Amazon.
Here is the product page, they also offer singles but it’s not much cheaper so I bought two in case it was a dud or I need another in the future.
Framework are sending me another battery. I said “maybe send me a few as I’ll need them if I’m keeping it?”
As an owner of an 11th Gen. Framework Laptop that has been experiencing this problem for months now, I just want to add a couple of points. At this point my experiences with Framework Support do not give me much hope that doing so will lead to anything productive; I just feel they should be on the record somewhere.
First. Through its entire handling of this problem, Framework has taken a dismissive tone towards anyone who does not use their Framework Laptop as their primary computing device. I have a desktop workstation I do most of my actual work on; my laptop is a backup device to be used when I’m away from my desktop. This means that, yes, my laptop will sit in my bag for weeks or even months sometimes between uses. I’ve been using laptops of many brands that way for 20+ years now, and this is the first time it’s ever caused a problem. I have never had a laptop with a fully charged main battery fail to power up the way my Framework routinely does. Never. Not once.
But in every communication I’ve had with Framework Support – including the posts in this thread! – they go out of their way to tell me that the actual problem is me. I’m using the laptop wrong.
Even @nrp does this in the post above: “the vast majority of 11th Gen users, who are using their laptops more often than every few weeks or months or who keep their laptop plugged into power when not in use…”
I want to offer you an apology. I’m sorry that I don’t use your product the way you want me to. An easy way to end this heartache would have been to have your Support personnel offer me a refund when it became clear to them that I was the (as you continually tell me, exceedingly rare) customer who is too dumb to appreciate the brilliance of your design. Nobody did that, of course.
Second. Framework has made multiple public statements, including in this thread, about being ready to offer replacement hardware to owners of 11th Gen. devices that have this problem. (In the past that readiness has been said to extend all the way to replacing the mainboard, though now it appears to have been scaled back to just the RTC cell.)
I have been in communication with Framework Support regarding this problem for nine months now. I want to emphasize this: at no time, even today, have they ever offered me hardware replacement. Not once. They simply have not ever brought the subject up.
And it’s actually even worse that that. Not only do they not proactively offer replacement hardware, when I have asked them directly about getting replacement hardware – even pointing directly to those public statements! – they do not answer. They tell me to go update my BIOS, or reset the mainboard again, or try leaving the laptop plugged in for another long period.
They do not offer hardware replacement, or even provide a way to apply for hardware replacement, even when directly asked about it. I’m at the point now where I assume they are actively trying to stall me until the warranty period ends.
All of this has been extraordinarily frustrating. The actual technical problem doesn’t bother me so much – it’s a first-generation product, these things happen. But your support experience has turned me off ever buying a Framework product ever again. I simply do not trust you to stand by your products.
I am sorry that you had this experience, but I had a complete different experience with the framework support team. They were always kind and friendly to me, they never blamed my usage habits and they offered me a replacement even though I never asked for it!
I just replied, because I don’t think it is fair to say, that they treated anyone like your statement above. They did not treat me like that.
Do as I have and write it off as a bad job. Framework are sending me a new battery…which will be dead in a few months…
This machine is largely unsuitable for my needs as it is. I’ve actually gone back to my 12 year old Dell. It works!
Once bitten… Win some lose some. Sometimes trying to do the right thing bites you hard.
It was fun the first few months.
@Jason_Dagless It really sucks that is the attitude you have. Not that I blame you, you have reason to feel that way, it just is really poor that this issue hasn’t been handled well.
