Wakeup from suspend with lid closed using usb keyboard not works
Which Linux distro are you using? UBUNTU
Which release version?
Ubuntu 24.04.3 LTS
Which kernel are you using? Linux 6.14.0-29-generic
Which BIOS version are you using? Latest
AMD Ryzen™ AI 370HX
Hi, my framework resume after suspend only with the internal keyboard with lid open.
If i try to wake up the pc using my USB keyboard not works.
Here my wakeup:
➜ riccardo ~ cat /proc/acpi/wakeup
Device S-state Status Sysfs node
GPP0 S4 *enabled pci:0000:00:01.1
SWUS S4 *disabled
GPP1 S4 *enabled pci:0000:00:01.2
SWUS S4 *disabled
GPP3 S4 *enabled pci:0000:00:02.1
GPP5 S4 *enabled pci:0000:00:02.3
XHC1 S3 *enabled pci:0000:c1:00.4
XHC0 S3 *enabled pci:0000:c3:00.0
XHC3 S3 *enabled pci:0000:c3:00.3
XHC4 S3 *enabled pci:0000:c3:00.4
NHI0 S4 *enabled pci:0000:c3:00.5
NHI1 S4 *enabled pci:0000:c3:00.6
And enabled devices (the usb keyboard is on 5.1)
➜riccardo ~ grep . /sys/bus/usb/devices/*/power/wakeup
/sys/bus/usb/devices/1-1/power/wakeup:disabled
/sys/bus/usb/devices/3-1/power/wakeup:disabled
/sys/bus/usb/devices/3-5/power/wakeup:disabled
/sys/bus/usb/devices/5-1.4/power/wakeup:enabled
/sys/bus/usb/devices/5-1/power/wakeup:enabled
/sys/bus/usb/devices/7-1/power/wakeup:disabled
/sys/bus/usb/devices/usb1/power/wakeup:disabled
/sys/bus/usb/devices/usb2/power/wakeup:disabled
/sys/bus/usb/devices/usb3/power/wakeup:disabled
/sys/bus/usb/devices/usb4/power/wakeup:disabled
/sys/bus/usb/devices/usb5/power/wakeup:disabled
/sys/bus/usb/devices/usb6/power/wakeup:disabled
/sys/bus/usb/devices/usb7/power/wakeup:disabled
/sys/bus/usb/devices/usb8/power/wakeup:disabled
This is very useful for me because i keep the lid closed 80% of the time.
Can you help me?
