What eDP cable do I need for a touchscreen?
I have a 14 inch touch screen (40pin) and 11 gen mainboard but i dont have a edp cabel. So my question is what cabel do in need to buy?
Available now in the Marketplace: Framework
Beware, I don’t believe a 40pin touchscreen is compatible! You would need a custom-made cable. Not the cable which is currently available from Framework.
See here:
The Framework-13 uses a four eDP lane 40-pin connector. That is a different configuration / different pinout from a touchscreen 40-pin connector.
Framework-13 motherboard side connector pinout: Framework-Laptop-13/Mainboard at main · FrameworkComputer/Framework-Laptop-13 · GitHub
Display side connector pinout: Framework-Laptop-13/Display at main · FrameworkComputer/Framework-Laptop-13 · GitHub
Four eDP lanes. No touch signals on the display side.
