Hi,
from the website it’s not clear what materials are used for the laptop.
Is it full-body aluminum, as for macbook, or it’s cheap plastic?
Or mix of both?
And what is brightness of the display? How many nit?
Would be nice to see sane comparison with other company laptops.
With Surface. With macbook pro. With Think pad.
Do you know anything like this in the wild?
The Framework 13 case is solid aluminum. Not as nice as full body magnesium or some composite materials, but otherwise okay. There are some sharp edges.
The display brightness can be found in the specifications. There are two different displays. Both are bright enough.
