What should i do? problem with Qubes v4.2.4?
Hello, I am using Framework Laptop 13 with Inter Core Ultra 7 165H, and I did try my effort to install Qubes v4.2.4. But I am not sure is not reboot from last step of the installation. I did manual shut down in laptop. After turning on again is not boot well.
what should i do?
You will likely get better help on this from the Qubes OS forums:
