Hey all,
I made a project that allows one to make a widget-based layout to display on the official LED matrix module. It currently supports Windows, but I am planning on supporting Linux very soon (it may or may not function right now on Linux). I am planning on running Linux again on my Framework now that I have fixed my SSD’s firmware, so all features should be supported on there in the coming days.
So far, I have implemented a simple rectangle widget, a clock widget with multiple fonts, and a bar widget which can display your battery percentage as a progress bar.
Future widgets I have in mind include a basic text widget, more shapes, more values that a bar can display (like CPU and RAM usage), and more, but if you can code and you don’t want to wait, custom widgets can be easily created using Python, and they will be loaded into the program by dropping them in a specific folder. This whole project is meant to be easily modular.
It can also be set to run when you log into your computer, making it a “set it and forget it” type of program. When you don’t need to configure it, it’ll sit in your system tray while updating the LED matrix.
I know that solutions like this already exist, but I wanted one that is based on a GUI and can automatically run on startup without having to tinker with files manually.
Please give it a try and let me know how it can improve! Thanks.
P.S. I am making this project as part of Hack Club Shipwrecked, so if you wouldn’t mind starring the project on GitHub, it would help me out a ton.
