Hi,
Bought a new laptop with configuration:
CPU: 11th Gen Intel i7-1165G7 (8) @ 4.700GHz
Kernel: 5.14.0-9parrot1-amd64
OS: Parrot OS 5.0 (LTS) x86_64
Host: HP ProBook 450 G8 Notebook PC
My wifi ( Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi) is not working with internal Wifi card and working with an external adapter it is not damaged (works with windows 11) and I am stuck with this for 2 months.
OTHER QUESTIONS:
Is Bluetooth working? > Yes it is working fine.
Does Wifi stopped after any update? > No, It did’nt work since I installed linux.
TERMINAL OUTPUTS:
sudo modinfo iwlwifi
filename: /lib/modules/5.14.0-9parrot1-amd64/kernel/drivers/net/wireless/intel/iwlwifi/iwlwifi.ko
license: GPL
author: Intel Corporation linuxwifi@intel.com
description: Intel(R) Wireless WiFi driver for Linux
firmware: iwlwifi-100-5.ucode
firmware: iwlwifi-1000-5.ucode
firmware: iwlwifi-135-6.ucode
and so many other files list
sudo dmesg | grep iwlwifi
Very long List
sudo dmesg | grep ASSERT
[ 5839.393084] iwlwifi 0000:00:14.3: 0x201002FF | ADVANCED_SYSASSERT
[ 5840.127172] iwlwifi 0000:00:14.3: 0x201002FF | ADVANCED_SYSASSERT
[ 5840.317880] iwlwifi 0000:00:14.3: 0x201002FF | ADVANCED_SYSASSERT
[ 5841.509222] iwlwifi 0000:00:14.3: 0x201002FF | ADVANCED_SYSASSERT
[ 5842.325477] iwlwifi 0000:00:14.3: 0x201002FF | ADVANCED_SYSASSERT
[ 5842.516446] iwlwifi 0000:00:14.3: 0x201002FF | ADVANCED_SYSASSERT
[ 5843.789616] iwlwifi 0000:00:14.3: 0x201002FF | ADVANCED_SYSASSERT
[ 5844.644453] iwlwifi 0000:00:14.3: 0x201002FF | ADVANCED_SYSASSERT
[ 5844.837702] iwlwifi 0000:00:14.3: 0x201002FF | ADVANCED_SYSASSERT
[ 5846.208709] iwlwifi 0000:00:14.3: 0x201002FF | ADVANCED_SYSASSERT
[ 5847.035788] iwlwifi 0000:00:14.3: 0x201002FF | ADVANCED_SYSASSERT
[ 5847.228445] iwlwifi 0000:00:14.3: 0x201002FF | ADVANCED_SYSASSERT
[ 5848.468514] iwlwifi 0000:00:14.3: 0x201002FF | ADVANCED_SYSASSERT
[ 5849.216785] iwlwifi 0000:00:14.3: 0x201002FF | ADVANCED_SYSASSERT
[ 5849.409404] iwlwifi 0000:00:14.3: 0x201002FF | ADVANCED_SYSASSERT
[ 5850.644810] iwlwifi 0000:00:14.3: 0x201002FF | ADVANCED_SYSASSERT
sudo lshw -C network
*-network UNCLAIMED
description: Network controller
product: Wi-Fi 6 AX201
vendor: Intel Corporation
physical id: 14.3
bus info: pci@0000:00:14.3
version: 20
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress msix bus_master cap_list
configuration: latency=0
resources: iomemory:600-5ff memory:600324c000-600324ffff
*-network
description: Ethernet interface
product: RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
vendor: Realtek Semiconductor Co., Ltd.
physical id: 0
bus info: pci@0000:02:00.0
logical name: eth0
version: 15
serial: 48:9e:bd:51:4c:c8
capacity: 1Gbit/s
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress msix bus_master cap_list ethernet physical tp 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=r8168 driverversion=8.048.03-NAPI latency=0 link=no multicast=yes port=twisted pair
resources: irq:145 ioport:3000(size=256) memory:54004000-54004fff memory:54000000-54003fff
*-network
description: Wireless interface
physical id: 2
bus info: usb@3:6
logical name: wlan0
serial: 1c:bf:ce:79:b9:b5
capabilities: ethernet physical wireless
configuration: broadcast=yes driver=mt7601u driverversion=5.14.0-9parrot1-amd64 firmware=N/A ip=192.168.10.12 link=yes multicast=yes wireless=IEEE 802.11
What I tried Before:
Updating Firmware from Here but no use
- I updated my firmware by downloading and copying this to /lib/firmware but wifi still not working
Searching Wifi in Bios:
- It is working in bios
Copying Wifi 6 AX201 drivers from here and paste in /lib/firmware
- I downloaded these drivers and pasted in /lib/firmware (even all .ucode file were there but I replaced them) but no use
Pressing F3 for Third party ROM Management and wifi was working and connected there via card AX201
As you can see WiFi is connected:
NOTE: Wifi is not working on Fedora Live, Ubuntu Live and nor on Kali and Parrot is my main Issue
WHAT SHOULD I DO NOW???
