Wifi 7 chipset recommendations?
Running Debian Trixie/Testing.
I bought a RT-BE96U recently (tri-band, 320mHz, 4x4, because future-proofing) and was looking for a good Linux-compatible M.2 wifi 7 chipset. Looking around, I found…
  • Intel’s BE200 is a no-go because of compatibility issues with AMD
  • MediaTek’s MT7925 (tri-band, 160mHz, 2x2) which has an in-kernel driver
  • The MT7927 is the 7925 with 320mHz support, but lacks a driver still
  • There’s the MT7996 (tri-band, 320mHz, 4x4) which has an in-kernel driver, but I can’t find anything using it yet
  • There’s the Qualcomm QCNCM865 (tri-band, 320mHz, 2x2) as well, but I don’t have experience with Qualcomm chipsets and can’t find any others. The ath12k driver is supposed to support it, kinda, sorta, your millage may vary from what I’ve seen
  • I’m not even going to look at Realtek because I do have experience with theirs…
Would it be best to wait and see what comes out later that uses the MT7996, simply grab a MT7925, try my luck with a QCNCM865, or is there a chipset I’ve overlooked or didn’t find?
Hello! I’m using the Qualcomm chipset and as of kernel 6.11 for Linux it should be plug and play.
Thank you for compiling a list of the various models I’ve seen mentioned around the forums. Seems pretty comprehensive of the options as I know it.
I’ve been holding off from upgrading to Wifi7 until there is a decent 4x4 chipset with good support. It’s a shame I can’t find the MT7996 anywhere.
