Wireless XBOX 360 Adapter Causes Panic Shutdown
This is with one of the unofficial XBOX 360 wireless adapters. It works fine on other PCs running the same distro and kernel. Syslog shows it going into a loop trying to initialize and then the laptop just shuts off. What’s interesting is that while the end result is the same regardless of which USB port I use, if I use the one plugged in to the same side as my HDMI module, it causes several syslog messages related to that in the process.
             ...-:::::-...                 seamonkey@brontital
          .-MMMMMMMMMMMMMMM-.              -------------------
      .-MMMM`..-:::::::-..`MMMM-.          OS: Linux Mint 20.2 x86_64
    .:MMMM.:MMMMMMMMMMMMMMM:.MMMM:.        Host: Laptop A6
   -MMM-M---MMMMMMMMMMMMMMMMMMM.MMM-       Kernel: 5.13.18-xanmod1
 `:MMM:MM`  :MMMM:....::-...-MMMM:MMM:`    Uptime: 9 mins
 :MMM:MMM`  :MM:`  ``    ``  `:MMM:MMM:    Packages: 2557 (dpkg)
.MMM.MMMM`  :MM.  -MM.  .MM-  `MMMM.MMM.   Shell: zsh 5.8
:MMM:MMMM`  :MM.  -MM-  .MM:  `MMMM-MMM:   Resolution: 2256x1504
:MMM:MMMM`  :MM.  -MM-  .MM:  `MMMM:MMM:   Terminal: /dev/pts/0
:MMM:MMMM`  :MM.  -MM-  .MM:  `MMMM-MMM:   CPU: 11th Gen Intel i7-1165G7 (8) @ 4.700GHz
.MMM.MMMM`  :MM:--:MM:--:MM:  `MMMM.MMM.   GPU: Intel Device 9a49
 :MMM:MMM-  `-MMMMMMMMMMMM-`  -MMM-MMM:    Memory: 887MiB / 64103MiB
  :MMM:MMM:`                `:MMM:MMM:
   .MMM.MMMM:--------------:MMMM.MMM.
     '-MMMM.-MMMMMMMMMMMMMMM-.MMMM-'
       '.-MMMM``--:::::--``MMMM-.'
            '-MMMMMMMMMMMMM-'
Side opposite HDMI module:
Sep 18 14:23:09 brontital kernel: [ 7236.488455] usb 3-4: new full-speed USB device number 16 using xhci_hcd        │
│Sep 18 14:23:09 brontital kernel: [ 7236.688479] usb 3-4: New USB device found, idVendor=045e, idProduct=0291, bcdDevice= 1.07        │
│Sep 18 14:23:09 brontital kernel: [ 7236.688486] usb 3-4: New USB device strings: Mfr=0, Product=0, SerialNumber=0        │
│Sep 18 14:23:09 brontital mtp-probe: checking bus 3, device 16: "/sys/devices/pci0000:00/0000:00:14.0/usb3/3-4"        │
│Sep 18 14:23:09 brontital mtp-probe: bus: 3, device: 16 was not an MTP device        │
│Sep 18 14:23:09 brontital upowerd[858]: treating change event as add on /sys/devices/pci0000:00/0000:00:14.0/usb3/3-4        │
│Sep 18 14:23:12 brontital kernel: [ 7239.796616] usb 3-4: USB disconnect, device number 16        │
│Sep 18 14:23:13 brontital kernel: [ 7240.428421] usb 3-4: new full-speed USB device number 17 using xhci_hcd        │
│Sep 18 14:23:13 brontital kernel: [ 7240.846544] usb 3-4: New USB device found, idVendor=045e, idProduct=0291, bcdDevice= 1.07        │
│Sep 18 14:23:13 brontital kernel: [ 7240.846552] usb 3-4: New USB device strings: Mfr=0, Product=0, SerialNumber=0        │
│Sep 18 14:23:13 brontital mtp-probe: checking bus 3, device 17: "/sys/devices/pci0000:00/0000:00:14.0/usb3/3-4"        │
│Sep 18 14:23:13 brontital mtp-probe: bus: 3, device: 17 was not an MTP device        │
│Sep 18 14:23:13 brontital upowerd[858]: treating change event as add on /sys/devices/pci0000:00/0000:00:14.0/usb3/3-4        │
│Sep 18 14:23:15 brontital kernel: [ 7243.184540] usb 3-4: USB disconnect, device number 17        │
│Sep 18 14:23:16 brontital kernel: [ 7243.814400] usb 3-4: new full-speed USB device number 18 using xhci_hcd        │
│Sep 18 14:23:16 brontital kernel: [ 7244.222587] usb 3-4: New USB device found, idVendor=045e, idProduct=0291, bcdDevice= 1.07        │
│Sep 18 14:23:16 brontital kernel: [ 7244.222595] usb 3-4: New USB device strings: Mfr=0, Product=0, SerialNumber=0        │
│Sep 18 14:23:16 brontital mtp-probe: checking bus 3, device 18: "/sys/devices/pci0000:00/0000:00:14.0/usb3/3-4"        │
│Sep 18 14:23:16 brontital mtp-probe: bus: 3, device: 18 was not an MTP device        │
│Sep 18 14:23:16 brontital upowerd[858]: treating change event as add on /sys/devices/pci0000:00/0000:00:14.0/usb3/3-4        │
Side with HDMI module:
Sep 18 14:25:18 brontital kernel: [   47.077118] usb 3-1: new full-speed USB device number 6 using xhci_hcd
Sep 18 14:25:18 brontital kernel: [   47.278366] usb 3-1: New USB device found, idVendor=045e, idProduct=0291, bcdDevice= 1.07
Sep 18 14:25:18 brontital kernel: [   47.278374] usb 3-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Sep 18 14:25:18 brontital mtp-probe: checking bus 3, device 6: "/sys/devices/pci0000:00/0000:00:14.0/usb3/3-1"
Sep 18 14:25:18 brontital mtp-probe: bus: 3, device: 6 was not an MTP device
Sep 18 14:25:18 brontital upowerd[880]: treating change event as add on /sys/devices/pci0000:00/0000:00:14.0/usb3/3-1
Sep 18 14:25:18 brontital kernel: [   47.356915] usbcore: registered new interface driver xpad
Sep 18 14:25:20 brontital kernel: [   49.591082] usb 3-1: USB disconnect, device number 6
Sep 18 14:25:20 brontital kernel: [   49.713696] usb 3-3: USB disconnect, device number 2
Sep 18 14:25:21 brontital kernel: [   50.762188] usb 3-1: new full-speed USB device number 7 using xhci_hcd
Sep 18 14:25:22 brontital kernel: [   50.963260] usb 3-1: New USB device found, idVendor=045e, idProduct=0291, bcdDevice= 1.07
Sep 18 14:25:22 brontital kernel: [   50.963267] usb 3-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Sep 18 14:25:22 brontital mtp-probe: checking bus 3, device 7: "/sys/devices/pci0000:00/0000:00:14.0/usb3/3-1"
Sep 18 14:25:22 brontital mtp-probe: bus: 3, device: 7 was not an MTP device
Sep 18 14:25:22 brontital kernel: [   51.520910] usb 3-3: new full-speed USB device number 8 using xhci_hcd
Sep 18 14:25:22 brontital kernel: [   51.728359] usb 3-3: New USB device found, idVendor=32ac, idProduct=0002, bcdDevice= 0.00
Sep 18 14:25:22 brontital kernel: [   51.728362] usb 3-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Sep 18 14:25:22 brontital kernel: [   51.728362] usb 3-3: Product: HDMI Expansion Card
Sep 18 14:25:22 brontital kernel: [   51.728363] usb 3-3: Manufacturer: Framework
Sep 18 14:25:22 brontital kernel: [   51.728364] usb 3-3: SerialNumber: 11AD1D0024672E0916260B00
Sep 18 14:25:22 brontital kernel: [   51.737001] hid-generic 0003:32AC:0002.0005: hiddev0,hidraw2: USB HID v1.11 Device [Framework HDMI Expansion Card] on usb-0000:00:14.0-3/input1
Sep 18 14:25:22 brontital mtp-probe: checking bus 3, device 8: "/sys/devices/pci0000:00/0000:00:14.0/usb3/3-3"
Sep 18 14:25:22 brontital mtp-probe: bus: 3, device: 8 was not an MTP device
Sep 18 14:25:24 brontital kernel: [   53.023240] usb 3-1: USB disconnect, device number 7
Sep 18 14:25:24 brontital kernel: [   53.144241] usb 3-3: USB disconnect, device number 8
Sep 18 14:25:25 brontital kernel: [   54.132848] usb 3-1: new full-speed USB device number 9 using xhci_hcd
Sep 18 14:25:25 brontital kernel: [   54.333672] usb 3-1: New USB device found, idVendor=045e, idProduct=0291, bcdDevice= 1.07
Sep 18 14:25:25 brontital kernel: [   54.333674] usb 3-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Sep 18 14:25:25 brontital upowerd[880]: treating change event as add on /sys/devices/pci0000:00/0000:00:14.0/usb3/3-1
Sep 18 14:25:25 brontital mtp-probe: checking bus 3, device 9: "/sys/devices/pci0000:00/0000:00:14.0/usb3/3-1"
Sep 18 14:25:25 brontital mtp-probe: bus: 3, device: 9 was not an MTP device
Sep 18 14:25:26 brontital kernel: [   54.896796] usb 3-3: new full-speed USB device number 10 using xhci_hcd
Sep 18 14:25:26 brontital kernel: [   55.312822] usb 3-3: New USB device found, idVendor=32ac, idProduct=0002, bcdDevice= 0.00
Sep 18 14:25:26 brontital kernel: [   55.312830] usb 3-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Sep 18 14:25:26 brontital kernel: [   55.312832] usb 3-3: Product: HDMI Expansion Card
Sep 18 14:25:26 brontital kernel: [   55.312834] usb 3-3: Manufacturer: Framework
Sep 18 14:25:26 brontital kernel: [   55.312836] usb 3-3: SerialNumber: 11AD1D0024672E0916260B00
Sep 18 14:25:26 brontital kernel: [   55.322785] hid-generic 0003:32AC:0002.0006: hiddev0,hidraw2: USB HID v1.11 Device [Framework HDMI Expansion Card] on usb-0000:00:14.0-3/input1
Sep 18 14:25:26 brontital mtp-probe: checking bus 3, device 10: "/sys/devices/pci0000:00/0000:00:14.0/usb3/3-3"
Sep 18 14:25:26 brontital mtp-probe: bus: 3, device: 10 was not an MTP device
Sep 18 14:25:27 brontital kernel: [   56.402404] usb 3-1: USB disconnect, device number 9
Sep 18 14:25:27 brontital kernel: [   56.524296] usb 3-3: USB disconnect, device number 10
Sep 18 14:25:28 brontital kernel: [   57.515849] usb 3-1: new full-speed USB device number 11 using xhci_hcd
Sep 18 14:25:28 brontital kernel: [   57.717055] usb 3-1: New USB device found, idVendor=045e, idProduct=0291, bcdDevice= 1.07
Sep 18 14:25:28 brontital kernel: [   57.717062] usb 3-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Sep 18 14:25:28 brontital mtp-probe: checking bus 3, device 11: "/sys/devices/pci0000:00/0000:00:14.0/usb3/3-1"
Sep 18 14:25:28 brontital mtp-probe: bus: 3, device: 11 was not an MTP device
Sep 18 14:25:29 brontital kernel: [   58.277111] usb 3-3: new full-speed USB device number 12 using xhci_hcd
Sep 18 14:25:29 brontital kernel: [   58.694237] usb 3-3: New USB device found, idVendor=32ac, idProduct=0002, bcdDevice= 0.00
Sep 18 14:25:29 brontital kernel: [   58.694245] usb 3-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Sep 18 14:25:29 brontital kernel: [   58.694248] usb 3-3: Product: HDMI Expansion Card
Sep 18 14:25:29 brontital kernel: [   58.694250] usb 3-3: Manufacturer: Framework
Sep 18 14:25:29 brontital kernel: [   58.694252] usb 3-3: SerialNumber: 11AD1D0024672E0916260B00
Sep 18 14:25:29 brontital kernel: [   58.703680] hid-generic 0003:32AC:0002.0007: hiddev0,hidraw2: USB HID v1.11 Device [Framework HDMI Expansion Card] on usb-0000:00:14.0-3/input1
Sep 18 14:25:29 brontital mtp-probe: checking bus 3, device 12: "/sys/devices/pci0000:00/0000:00:14.0/usb3/3-3"
Sep 18 14:25:29 brontital mtp-probe: bus: 3, device: 12 was not an MTP device
Sep 18 14:25:30 brontital kernel: [   59.782547] usb 3-1: USB disconnect, device number 11
Sep 18 14:25:31 brontital kernel: [   59.903343] usb 3-3: USB disconnect, device number 12
Sep 18 14:25:31 brontital kernel: [   60.896326] usb 3-1: new full-speed USB device number 13 using xhci_hcd
Sep 18 14:25:32 brontital kernel: [   61.097786] usb 3-1: New USB device found, idVendor=045e, idProduct=0291, bcdDevice= 1.07
Sep 18 14:25:32 brontital kernel: [   61.097794] usb 3-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Sep 18 14:25:32 brontital mtp-probe: checking bus 3, device 13: "/sys/devices/pci0000:00/0000:00:14.0/usb3/3-1"
Sep 18 14:25:32 brontital mtp-probe: bus: 3, device: 13 was not an MTP device
Sep 18 14:25:32 brontital kernel: [   61.657051] usb 3-3: new full-speed USB device number 14 using xhci_hcd
Sep 18 14:25:33 brontital kernel: [   62.075686] usb 3-3: New USB device found, idVendor=32ac, idProduct=0002, bcdDevice= 0.00
Sep 18 14:25:33 brontital kernel: [   62.075693] usb 3-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Sep 18 14:25:33 brontital kernel: [   62.075696] usb 3-3: Product: HDMI Expansion Card
Sep 18 14:25:33 brontital kernel: [   62.075698] usb 3-3: Manufacturer: Framework
Sep 18 14:25:33 brontital kernel: [   62.075699] usb 3-3: SerialNumber: 11AD1D0024672E0916260B00
Sep 18 14:25:33 brontital kernel: [   62.085948] hid-generic 0003:32AC:0002.0008: hiddev0,hidraw2: USB HID v1.11 Device [Framework HDMI Expansion Card] on usb-0000:00:14.0-3/input1
Sep 18 14:25:33 brontital mtp-probe: checking bus 3, device 14: "/sys/devices/pci0000:00/0000:00:14.0/usb3/3-3"
Sep 18 14:25:33 brontital mtp-probe: bus: 3, device: 14 was not an MTP device
Tried removing all of my modules except for a single USB module, and that yielded different messages.
Sep 18 14:47:28 brontital kernel: [  118.853019] usb 3-4: new full-speed USB device number 51 using xhci_hcd        │
│Sep 18 14:47:28 brontital kernel: [  118.971133] usb 3-4: Device not responding to setup address.        │
│Sep 18 14:47:28 brontital kernel: [  119.180941] usb 3-4: Device not responding to setup address.        │
│Sep 18 14:47:28 brontital kernel: [  119.388889] usb 3-4: device not accepting address 51, error -71        │
│Sep 18 14:47:28 brontital kernel: [  119.714814] usb 3-4: new full-speed USB device number 52 using xhci_hcd        │
│Sep 18 14:47:29 brontital kernel: [  119.850638] usb 3-4: New USB device found, idVendor=045e, idProduct=0291, bcdDevice= 1.07        │
│Sep 18 14:47:29 brontital kernel: [  119.850645] usb 3-4: New USB device strings: Mfr=0, Product=0, SerialNumber=0        │
│Sep 18 14:47:29 brontital mtp-probe: checking bus 3, device 52: "/sys/devices/pci0000:00/0000:00:14.0/usb3/3-4"        │
│Sep 18 14:47:29 brontital mtp-probe: bus: 3, device: 52 was not an MTP device        │
│Sep 18 14:47:29 brontital upowerd[882]: treating change event as add on /sys/devices/pci0000:00/0000:00:14.0/usb3/3-4        │
│Sep 18 14:47:30 brontital kernel: [  121.743790] usb 3-4: USB disconnect, device number 52
Moving the USB module to the upper left (with the laptop face up) port allowed the adapter to be properly initialized. This was still with a single module installed.
Sep 18 14:54:34 brontital kernel: [  131.281675] usb 3-6: new full-speed USB device number 5 using xhci_hcd        │
│Sep 18 14:54:34 brontital kernel: [  131.399850] usb 3-6: Device not responding to setup address.        │
│Sep 18 14:54:35 brontital kernel: [  131.615767] usb 3-6: Device not responding to setup address.        │
│Sep 18 14:54:35 brontital kernel: [  131.823649] usb 3-6: device not accepting address 5, error -71        │
│Sep 18 14:54:35 brontital kernel: [  132.149726] usb 3-6: new full-speed USB device number 6 using xhci_hcd        │
│Sep 18 14:54:35 brontital kernel: [  132.287810] usb 3-6: New USB device found, idVendor=045e, idProduct=0291, bcdDevice= 1.07        │
│Sep 18 14:54:35 brontital kernel: [  132.287850] usb 3-6: New USB device strings: Mfr=0, Product=0, SerialNumber=0        │
│Sep 18 14:54:35 brontital mtp-probe: checking bus 3, device 6: "/sys/devices/pci0000:00/0000:00:14.0/usb3/3-6"        │
│Sep 18 14:54:35 brontital mtp-probe: bus: 3, device: 6 was not an MTP device        │
│Sep 18 14:54:35 brontital upowerd[866]: treating change event as add on /sys/devices/pci0000:00/0000:00:14.0/usb3/3-6        │
│Sep 18 14:54:35 brontital kernel: [  132.472867] usbcore: registered new interface driver xpad        │
│Sep 18 14:54:45 brontital kernel: [  141.650957] input: Xbox 360 Wireless Receiver (XBOX) as /devices/pci0000:00/0000:00:14.0/usb3/3-6/3-6:1.0/input/input26
Plugged my other modules back in, and it seems as long as I’m using that specific port for the USB module, it intializes. However, this time, it also caused the touchpad to stop functioning.
Sep 18 15:01:50 brontital kernel: [   93.866755] usb 3-6: new full-speed USB device number 6 using xhci_hcd        │
│Sep 18 15:01:50 brontital kernel: [   94.067614] usb 3-6: New USB device found, idVendor=045e, idProduct=0291, bcdDevice= 1.07        │
│Sep 18 15:01:50 brontital kernel: [   94.067653] usb 3-6: New USB device strings: Mfr=0, Product=0, SerialNumber=0        │
│Sep 18 15:01:50 brontital mtp-probe: checking bus 3, device 6: "/sys/devices/pci0000:00/0000:00:14.0/usb3/3-6"        │
│Sep 18 15:01:50 brontital mtp-probe: bus: 3, device: 6 was not an MTP device        │
│Sep 18 15:01:50 brontital upowerd[866]: treating change event as add on /sys/devices/pci0000:00/0000:00:14.0/usb3/3-6        │
│Sep 18 15:01:50 brontital kernel: [   94.271835] usbcore: registered new interface driver xpad        │
│Sep 18 15:02:12 brontital kernel: [  116.488169] input: Xbox 360 Wireless Receiver (XBOX) as /devices/pci0000:00/0000:00:14.0/usb3/3-6/3-6:1.0/input/input22        │
│Sep 18 15:03:35 brontital kernel: [  198.753019] i2c_hid_acpi i2c-PIXA3854:00: i2c_hid_get_input: incomplete report (37/261)
Changed my module configuration again, and so far, no more errors. Final configuration with laptop face up:
2x USB-A on left side
HDMI and USB-C on right side
Could you try the steps here: https://knowledgebase.frame.work/en_us/one-port-on-my-laptop-does-not-function-correctly-r1mqMnTet
