I found this post with pictures, thank you @ImaxinarDM.
EDITED TO ADD LINK TO POST:
Once the screws are removed, the card appears to slide apart, but I am having a heck of a time getting mine apart. I’m trying not to bend the cover by using it as a lever. Any help appreciated, thanks!
Update - I was able to get the cover off by holding the card in both hands, USB-C connector facing up, label side facing me, pressing firmly with my thumbs and firmly but gently pushing toward the USB-C connector end.
Yes that’s what I had to do as well. They are pretty tight and have tiny fingers that engage to hold the top of the cover down, but once they are opened up the 1st time, it’s easier then on.
@ImaxinarDM - the pictures in your post that I linked above (edit, not about) were key, thank you for providing them! I had a couple of spare thermal pads and wanted to apply them to the storage cards per nrp’s post here:
I’m a dufus, I thought that I had linked his post. Yes, that’s the one, thank you for linking it.
I’ve updated the post to add the link, and corrected my grammar in the post that you quoted - it should have said the post that I linked above, not about
Thank you so much for this, your update saved me a lot of time while trying to find out how to open the USB-c module because mine just gave up all of a sudden. I wanted to take a look to see if there was anything that I could do to repair it.
I had a problem with sliding the lid open. I’ve found that cutting a long strip of tape, taping it on the lid and pulling on it helps a lot. You should also hold the tape in place with your thumb while pulling.
Excellent tip. I was having an awful time keeping my thumbs from sliding on this. A small piece of masking tape to tug up on got it open really easily!
