11th gen microphone problem
Hi
I am having an intermittent problem with the microphone on my first-generation 13 laptop. I think it’s down to the cable, as it passes the hinge. I have looked at the Framework Store for a replacement unit, but can not find one. Does anyone know of a replacement microphone and cable?
Thanks inantisapation, Steve
You most likely need just a replacement cable. Microphone cable is part of the webcam cable, and that is available, frame.work/marketplace?search=cable
The microphone itself is part of the webcam module. But it’s unlikely that the microphone itself is bad.
Thanks for your help, most appreciated, Steve
