Hi,
What is the perfect size of the privacy screen I should buy for my Framework 16?
Ideally without having to remove/overlap with the frame itself.
Hi,
There are two sources. One is PhotoDon, which recently added the 16 to their standard Laptop cuts. Another is the 3M BP160W1B. PhotoDon may be cheaper and the better overall value for those in the US at least, but both should work equally well.
I’m not really convinced by that; I don’t want to stick anything on. Shouldn’t there be something you can just clip under the frame?
