1tb expansion card powerdraw on linux mint 22.3
I recently bought a 1tb expansion card for my framework 16.
Its drawing ~900 mA on idle (I tested it in windows too and i don’t have the same problem there). Is there a better way to fix this then to manually power it of and scan for it again?
Hi there! Two questions for some additional information:
Which version of the FW 16 BIOS are you currently running?
Which slot are you inserting the drive into?
What’s the file system on your 1TB expansion and what’s the “mount option” on your Linux mint
Hi! I´m on bios version 4.03 and Iz have tried it in slots 4 and 5.
Hi! Its file system is FAT32 and these are the “mount options” (or did you mean anything else with that?):
