6Ghz Wifi Issues after upgrading BIOS from 3.04 to 3.06
Things were running fine until I started putting more load on the system with LLMs the last few weeks. The other day the system was unresponsive, so I decided it was time to see what BIOS updates were available. Picked 3.06 and flashed. Then I noticed my 6Ghz Wi-Fi would continuously disconnect.
Windows Event 1033 → 1036 → 1030 → 7001 → 1035 → 1035 (this repeats after 15, 30, sometimes a minute or two). Causing the connection to reestablish over and over. Switching to 5Ghz is stable. I have a single WAP about 8’ away.
I tried downgrading to 3.05, but the issue remains. There is no download for 3.04 that I can find, to test, so I can’t completely blame the BIOS. But it’s pretty coincidental. Gemini blames the reprogramming of the AMD PI code.
AMD PI 1.0.0.2c PCIe Link State Conflict (Most Likely)
  • Aggressive Clock Gating: The updated AMD Platform Initialization (PI) code forces stricter L1 PCIe sub-state power savings on the CPU’s root complex.
  • The Mechanism: When the RZ717 pauses briefly between data bursts on the 6GHz band, the AMD PCIe lane cuts power. Waking the lane back up causes a localized hardware delay, which causes your packets to back up (the latency spike) right before the driver panics and drops the link (DisAssoc).
Anyone else notice anything? I’d be OK downgrading to 3.04 to verify too.
Welcome to the forum :waving_hand:
Could you add here any relevant entries from your Windows Event Viewer logs, so readers can see some detail?
It might also be worth seeing if your router has some BIOS updates too. I wonder if 3.06 tightened things up in a good way, and it is your router that is not quite to spec.
The events don’t give much detail, but here they are:
1033 - DisAssoc
1036 - BSS RLM Info
1030 - Connect Info
7001 - Power Save Information
1035 - Send EAPOL
1035 - Send EAPOL
(this sequence continues in a loop at varying intervals from a few seconds to minutes at a time)
It’s a Ubiquiti U7 Pro XGS on 8.7.11. I’ll try a firmware update on it too.
Hmm, yeah, it’s a bit sparse. I’d probably next try a live CD for Ubuntu - it might either narrow it down to a BIOS problem (if it is the same behaviour) or a Windows problem (if it is different).
You could try downgrading back to BIOS 3.0.4
That version is missing from the downloads. Unless I’m blind, there’s a gap between 3.03 and 3.05.
WAP is already at the latest version, 8.7.11. Haven’t tried a live CD yet. (Note I changed my nickname)
Could also be the drivers. MediaTek drivers are notoriously garbage. My card was useless for both bluetooth and wifi since March. I replaced it with an Intel AX201. That isn’t a Framework problem so much as an AMD only has MediaTek as a wifi7 vendor problem.
Had no issues until right after the BIOS update.
Booted into Ubuntu desktop 26.04.1 and had the same continuous disconnects. I’m still leaning BIOS, but would like to downgrade back to 3.04.
Could be both the bios and the Mediatek drivers. My problems time probably to around 3.04 or 3.05. I’m usually running the latest bios. Which my Intel card being fine would point to something jank with how the mediatek talks to the Framework at a low level.
Granted I never tested it all on a windows environment so it could be a Linux and bios and drivers intersection of variables too. Have you dinged support?
I’ll look into the missing BIOS, in the mean time please reach out to support to file a ticket if you haven’t already.
