A call on 240w adapter
Oh no, I highly doubt it will work safely even if they reach out. I doubt that FW16 has electronics disigned to take more than 5A continuously, even if you reverse engineer the handshake. 240w is more than enough and it’s a full featured thunderbolt 5 dock.
Has anyone tried this sketchy looking 240W PSU?
Looks like there’s other similar looking adapters on there now too by other brands, I’d assume they’re probably the exact same product. My FW 240 is supposed to ship next month, but I’m using my FW 16 a lot more now and am itching to have a 2nd adapter so I don’t need to move it all the time.
Very interesting. I would be a little apprehensive about the level of QC that went into it and longevity (past the 30 day return window). Or it may be the best ever made….there is only one way to find out if you wanna risk $89.99. Or perhaps 1 person can buy(who also has a dGPU) to test it for the rest of us and we will need 10 volunteers to pitch in $9 each to help with the effort….Just an idea!
Maybe a safer bet. Try the FW 240W charger:
Probably only get it in December though. :frowning:
I already pre-ordered one, it should arrive Nov. I’m just antsy. I don’t plan to take the risk myself, but if someone here said “yeah, it works perfect” then I could pick it up as a 240 for now, and a backup in the bag for the future.
Same… I pre-ordered it back in August and won’t even ship until December.
That is way overpriced considering the no-name supplier. That Delta one (well known brand) was released at the same price ($90) originally.
Besides, no reason to buy any 240w right now until Framework fixes their firmware….if ever.
What is broken on the FW firmware?
I have a custom EC firmware that removes the games stutter problem, if that is what you need.
Warning: BIOS 4.01 appreciation post
4.01 solved all battery drain problems with 180W whan in Balanced mode and solved all the stuttering mess I had with the 240W Delta brick.
Running latest Windows (Atlas OS to be exact), 2.06 Framework OEM drivers (but Adrenaline updated to 25.10.01 optional in order to play Battlefield 6).
Issues persist using 140W Baseus charger, but 1) it’s not officially supported if you have the dGPU and 2) avoiding stuttering is possibile by using “Maximum efficiency” power plan or limiting the total TDP to ~60/65W using “Framework Control Center”, so not perfect but acceptable.
Has anyone had their FW 240W adapter ship yet? My batch 3 is supposed to ship in “November” but Nov. is almost gone and I haven’t even seen record of batch 1’s shipping yet.
I’m batch 2 and this morning I just got my pre-ship notification email.
“Your order is shipping soon! The outstanding balance will be charged in 3-18 days, and the order will be shipped 1-3 days after payment is complete.”
So mine wont begin its journey to me until 4-21 days have passed. Will be interesting to see if it operates better than the delta 240 charger.
Mine is batch #5 so it will be a little bit before I get mine. Please do share any testing results/experience in using it in various scenarios/heavy loads etc… very interested to know. Thanks!
Oh, it looks like I got the same message less than 30 minutes after my post, lol!
I bought this one from AliExpress, I think it’s the same.
Basically it has this issue where it randomly drops out charging. Sometimes it restarts in a few seconds causing stuttering in games because it switches TDP limits, and sometimes it just totally stops and falls back to my other 40w charger. Tried various combinations of moving USB C expansion port.
My machine is connected to a Thunderbolt dock at the same, so sometimes I check and the 240W charger dropped out and it’s using the 40W charging from my dock and my battery is at 70% because I’m using the dedicated GPU.
I’m using a Framework 16 AMD Ryzen 9 7940HS with BIOS 4.0.3
I bought a USB C PD tester, and it negotiates the 48V 5A fine, but just randomly drops out.
I expect this is a FW BIOS/EC issue, can provide any info necessary, hopefully FW investigates.
Stop using the aliexpress charger. 50V is not a valid PD voltage. 48V is. If the charger cannot get that right, what else is it doing wrong? I would not trust it.
Sorry, the PD tester indeed shows 48V, I remembered incorrectly. Edited post.
What does the pd tester say when it drops? Does it reduce from 48V to 20V or something like that?
Knowing what voltage it drops to helps.
EDIT:
Bios 4.03 seems to have fixed the issues I had with the 240W charger. Tried with both the 7700S and the 5070 (I’m on 7840HS). Using Delta 240W USBC charger I got last year from Digikey.
Trusting an aliexpress 240W charger with your $2000 laptop just to save like $15 is kinda wild to be honest. These things are unregulated and could potentially fail catastrophically. If it keeps dropping out, it means some components inside are passing their limits already.
The 180W official framework charger only does that if I mistakenly have it sandwiched between two couch cushions and it overheats.
It just goes off and on, so like it stopped getting power totally. When it’s back on it’s at 48V again. I have never seen it negotiate to a lower voltage after this problem.
