Has anyone had issues with their ram? I brought PNY laptop ram, 2x8GB SODIMM sticks at 3200MHz (DDR4).
Specs - XLR8 Gaming Memory
Compatible Speeds 3200, 3000, 2933, 2666, & 2400
Part # 8GBU1X08QJLL42-12-K - Dual Channel Kit
My issue is my laptop freezes up completely after 10 to 15 mins. of use. When I run one stick at a time and switch them in different channels, my laptop works fine. But, when I put them together within at least 10 mins of boot up. The laptop freezes up. I ran the memory tool on Windows 11 and it found no issues. I ran the tool on each stick individually and together. I looked up the speed it is running at and Windows states 3200MHz.
I tested my old laptop ram sticks from my HP. 1 Dimm is stock and is by Micron and the other Dimm is by Crucial - Ballistic (I added another stick later). These sticks are each 8GB and run at 2666MHz. Windows states there are running at 2400MHz. I noticed my laptop works perfectly fine with no issues.
Is it me or do these PNY DIMMs don’t work well with each other in dual channel mode?
I have the i5 12th Gen Framework laptop with a clean install of Windows 11.
