Hi,
When I’m using two recently purchased memory sticks, I get multiple BSOD daily but using each memory stick separately and in any of the two slots works as expected. I haven’t found anything related on the community forum. Before you ask, the RAM sticks were purchased as a bundle and I have tried every possible combination of memory sticks with RAM slot and only when using both of them at the same time do I get instability. Anyone has encountered a similar issue or has an idea of a fix? Maybe tweak BIOS settings like increasing RAM voltage or manually decreasing RAM frequency if that’s even possible?
Laptop processor: 12th Gen, i5-1240P, 1.70 GHz
OS: Windows 11 Version 22H2
Memory: Crucial 32GB (2 x 16GB) 260-Pin DDR4 SO-DIMM DDR4 3200 (PC4 25600) CT2K16G4SFD832A
BSOD stop codes: SYSTEM_SERVICE_EXCEPTION / CRITICAL_STRUCTURE_CORRUPTION / IRQL_NOT_LESS_OR_EQUAL / KMODE_EXCEPTION_NOT_HANDLED
