After using an M2 Macbook Air for a little while, I noticed that the colors of the Framework 16’s display appear more “washed out” than the Mac. This feels the most noticeable for dark gray: when opening the same app on the Mac and Framework side-by-side, the Mac appears to have much darker grays.
As these are completely different displays, I understand they will look different, but are there any ways to calibrate the Framework display to appear a bit closer to the Mac’s display?
Thank you!
Fedora 42
Which kernel are you using?
Linux 6.15.9-201.fc42.x86_64
IFGP6.03.05
Which Framework Laptop 16 model are you using?
AMD Ryzen™ 7040 Series
