Which Linux distro are you using? Fedora KDE Plasma/Fedora Workstation/Gnome
Which release version? 44
Which kernel are you using? 6.19.10-300.fc44.x86_64
Which BIOS version are you using? 04.02
Which Framework Laptop 13 model are you using? (AMD Ryzen™ AI 300 Series)
So I have just received my new framework and was finally able to migrate to Linux from having MacOS my whole life. So it could be that I am doing something wrong.
The issue is when installing Fedora KDE plasma on the fw, it worked fine for the first boot, but when I restarted it, it was stuck in boot. I tried reinstalling, because I had not actually done much on it yet, but then it failed the media check. If I forego the mediacheck and just start it up, it works again, until the first reboot, where again it gets stuck.
After a few failed attempts I tried Fedora Workstation (GNOME) which works perfectly fine.
Any ideas what could cause this?
