[ARCH] AMD Framework UI grinds to a halt randomly
Arch
Which release version?
27/12/2024
Which kernel are you using?
6.13.0-rc4
03.05
Which Framework Laptop 13 model are you using? (AMD Ryzen™ 7040 Series, Intel® Core™ Ultra Series 1, 13th Gen Intel® Core™ , 12th Gen Intel® Core™, 11th Gen Intel® Core™)
AMD Ryzen™ 7040
Seemingly randomly (while using firefox), the UI would grind to a halt, going down to 1-2 FPS. Need to reboot, which is possible but very slowly.
Nothing obvious in dmesg, cant really see a pattern (I used suspend/hibernate a lot, so might be a factor).
KDE with Wayland.
/cc @Mario_Limonciello
It’s probably related to Kwin(?) and adaptive sync; for some reason since 6.11, some things have been getting really weird. Turn off adaptive sync and see if that fixes anything. Also, give LTS a try to see if it’s at all related to the kernel (6.13 might come with it’s own problems).
Good, call! I’ve disabled it. If that doesn’t work I’ll try LTS.
Oh, that’s interesting! I experienced the same a while ago and just thought there was yet again some random failure condition as I didn’t see it again, yet. I am on the regular kernel (6.12).
