Audio expansion card 3.5mm socket part number
Does anybody know the part number of the 3.5mm socket that is used on the audio expansion card? A compatible one is fine, too.
Mine is worn out and I want to replace it, and I want to try my luck without buying a completely new expansion card.
Framework support says:
We don’t have information about the specific socket part used in the Audio Expansion Card, as we don’t recommend users attempt repairs at the component level. If the module isn’t working as expected, it’s generally more reliable to replace the entire Expansion Card instead.
Which is a bit antithetical to Framework’s mission statement, in my opinion. (I’m OK with voiding the warranty of the expansion card and possibly destroying it. I can go the route of buying a new one, then.)
Relevant photos here:
Expansion card:
Top side:
Bottom side:
This here looks close: https://www.digikey.ch/de/products/detail/adam-tech/ASJ-198-Y-HT-T-R/9832153
Not exactly the same, but you could compare the dimensions and pins to the data sheet.
hey, did you find the part? I want to design a HiFi DAC PCB to put inside the expansion card
I have not tried the part suggested by @Jonathan_Haas and haven’t looked further into it myself, since Framework agreed to send a replacement expansion card.
