Battery charge limit occasionally ignored
I think a simple reboot of the EC will suffice instead of going into BIOS and setting values back again.
EC reboot procedure:
  1. Power off the laptop (not suspend)
  2. Remove the PSU cable.
  3. Leave the laptop powered off for 2 minutes. (The EC powers off about 40 seconds after the CPU has shut down and the PSU cable removed, but that exact time is sometimes difficult to judge, so I say 2 minutes.)
  4. Plug PSU back in and power on the laptop.
The EC should have rebooted.
you can use “sudo ectool console” to see if the timestamps have started back at 0.
The power off and unplug PSU is important, because in many situations the EC stays on even with the CPU shutdown or rebooted.
I’ve noticed the same problems with Battery Life Extender and disabled it.
But I’ve also noticed, that is you start at higher percentage and the laptop runs on battery till it reaches the desired value then it toggles between charging and discharging.
On my old Dell XPS 13 it was possible to set the min and max charge value, so it did not charge until min is reached and then charged till max. For example between 60% and 90%. That was ok and my battery lastet at over 90% capactity for 8 years.
Adding to report this issue for the new Framework 13 AMD Ryzen AI 300 model as well. Battery charge limit is not consistently enforced even while Battery Life Extender is turned off.
Also seeing this issue with my FW13 HX370. It worked at first when I set it up, then it stopped. I have the battery life extender disabled as well.
Edit: Ok- I’m new to Framework. I can see there are beta BIOS releases being discussed here on the forums and they are aware and working on the issue! Framework Laptop 13 Ryzen 7040 BIOS 3.08 Release BETA - Held
Mostly just sending a thanks to everyone who’s commented and posted in this topic. I had the same issue with my 16, and due to this post I just disabled the extender option in the bios 3.05. not super worried about it because even when the machine fully charges the battery despite the bios limiter setting, it eventually goes back to holding at the set maximum charge value soon after. don’t know if the disabling will solve or a new bios update is necessary, but just wanted to point out that I did read somewhere else (possibly reddit) that the amd13’s bios actually requires the extender function enabled in order for the limiter to work right.
After the new BIOS update, I’m still having this problem. Anyone else?
Just got my Framework 16 and I’m running into it. Did you find any solution?
I’m still having the problem unfortunately. It’s very intermittent. Sometimes it doesn’t happen for a week, but eventually the battery will just fully charge.
I don’t think it matters, but what OS are you using?
I was using Windows 11 but then I transitioned over to using Bazzite.
Fedora KDE. Since it’s a BIOS setting, it’s weird to me that something keeps messing it up.
I’ve tried shutting the laptop off with it unplugged and that doesn’t seem to make any difference.
I’m barely confident it had something to do with the BIOS. I’m just not sure if this is a one-off issue or if it’s a more widespread issue that people just aren’t noticing. If it’s the former, I’m not sure how to fix it. I’ve already tried reflashing the BIOS.
