I have both sleep and hibernation disabled and fully shut down when not in use. Why would battery drain down to 0 percent if laptop left fully off for a couple of days? Is that normal? In the past on other laptops I usually left them plugged in
thanks,
dan
It is corrected, I think it was a bios update
