The last shutdown failed somehow (stuck for a very long time at the end of the sequence where normally the power goes off) so I had to kill it pressing the power button.
Today I open the lid and the laptop behaves for few seconds as if it was resuming from standby showing the last framebuffer (the powerdown log that was displayed before I killed it), keyboard backlight and power button LED. Then it went off.
Turned it on again, went through bios screen, so it was really off this time, and OS reports much lower battery than when I left it.
I had left it at “full” charge (bios limited at 85%), found it at 31%.
Not sure what I can do to investigate or reproduce this but I’d be happy to try stuff.
OS: Gentoo (kernel 6.7)
Been using this for few weeks, this never happened before and haven’t happened again yet.
Suspend is working on lid close (as I’ve read is the only supported way for now), however I think battery drains faster than it should while in it too.
Paste the output here. If the results are looking good and healthy, we’d want you to simply monitor battery behavior (idle especially as that’s the best indicator).
native-path: BAT1
serial: WA
power supply: yes
updated: Wed 22 Nov 2023 09:40:12 CET (6 seconds ago)
has history: yes
has statistics: yes
battery
present: yes
rechargeable: yes
state: discharging
warning-level: none
energy: 51.7806 Wh
energy-empty: 0 Wh
energy-full: 62.1367 Wh
energy-full-design: 60.6042 Wh
energy-rate: 11.5326 W
voltage: 16.654 V
charge-cycles: 15
time to empty: 4.5 hours
percentage: 83%
capacity: 100%
icon-name: 'battery-full-symbolic'
History (charge):
1700642322 83.000 discharging
History (rate):
1700642412 11.533 discharging
1700642382 13.390 discharging
1700642352 13.204 discharging
1700642322 14.350 discharging
I’ll leave the laptop closed/suspended for the whole day and see how it is after that.
But I noticed that after a full charge last night while powered off (again bios limited to 85%) I found it down to 83% and now in the time it took to write this already down to 81%.
