Best way to clean the FW16 RGB Keyboard
I work in a high diesel/soot environment and while I don’t need to clean my keyboard at this moment, I can see it getting dirty very fast in the future. Should I just wipe it down with denatured alcohol or is there something else I can do to keep it functioning well? Do the keys pop lose or would that ruin the keyboard?
Looks like isopropyl alcohol is ok
Framework staff has said keycaps are not meant to be removed, it risks breaking them. It’s the same for all normal laptops keyboards afaik.
If you know dirt becomes a problem over time, perhaps a universal silicone keyboard protector. I’ve used them, you can still feel the keys, due to them being so flexible and thin.
