Do you have any cleaning recommendation?
What chemicals are recommended for the screen, the body, the keyboard? What chemicals are not recommended?
Is there any procedure on cleaning the computer to avoid any damage?
I guess that the body is covered with paint?
You can use water and a microfiber cloth to clean everything. Personally, I use Whoosh as I find it cleans things really well but it’s not necessary.
Don’t use alcohol on the screen as it can damage it over time.
Just use a clean microfiber and don’t apply too much pressure, especially on the screen.
It’s anodization not paint.
Thank you for the tips.
Do you know what are the materials of the finish of the power button and the touchpad?
I believe it’s a glass layer on top of them
I am unclear as to how, or what, I should do when cleaning my Framework 16 Laptop. It’s kind of an important part of maintenance, and when the time comes, I would like to have a guide ready on how to clean my Framework without breaking.
It’s not important now, but I will definitely want this in five months.
Hi! I’ve been using a fw13 for some months now and from the use the zone where my palms rest and the exterior are now not as clean as I would love to. What are your recommendations/recommended products to clean it? In previous laptops I just used some soft towel with a bit of water or alcohol but they were plastic not aluminum '![]()
I add the following observation. The aluminium does not pick up grease easily, which is good. However, the bevel does.
Cleaning the surfaces of laptops*** (keyboards, case, cables, power supply) can typically be safely cleaned using the following order of increased cleaning ability.
*** DO NOT clean the screen with anything other than a clean, soft microfiber towel and if it has fingerprints/foreign matter dampen the cloth slightly with clean water then wipe gently; follow up with a dry portion of the microfiber to clean any streaks left behind from the damp cloth***
- Clean, dry, microfiber cloth.
- Clean, slightly damp, microfiber cloth.
- Clean, lightly dampened with Isopropyl or Denatured Alcohol, microfiber cloth.
- Clean, moderately damp with Isopropyl or Denatured Alcohol, microfiber cloth; slightly more pressure though not enough to deform the surface you are cleaning.
- If [4] above is not working; clean hands and work surfaces more often before using devices.
TL:dr
Almost all screens come with a “coating” that is commonly antireflective, color enhancing, and a protective barrier to the raw surface. Only use a clean microfiber cloth dampened with clean water at most to protect the factory coating on screens (this includes TV’s). Most are not aware that water itself is actually a solvent although a mild one.
For all the users who want to finger blast their screens because of this idea that touching a screen is a better experience for them; each touch leaves/smears oils, dirt, bacteria, dust, mites, etc. around the screen and is put on display light a Lite-Brite.
While I do not have a germ-phobia, it is fairly unappealing to see the evidence of touching a screen and then think about all the dirty things the prints have left behind or have carried over contamination from another source.
Generally most plastic and certainly aluminum can be safely cleaning with isopropyl or denatured alcohol without damage. Check in an inconspicuous place though if uncertain.
Hi @anon81945988,
It does not have to be a microfiber cloth. They are commonly used in detailing/cleaning vehicles. Generally they do not leave lint behind, and are not quite as absorbent as cotton is. Synthetic fibers will generate a small amount of static electricity which can attract and retain dust. ![]()
Pro tip from detailers: That little tag on new microfiber cloths? RIP IT OFF. Even if it frays the edge it is ok; the tag actually can leave scratches on more delicate surfaces.
Using a clean cotton cloth from old clothes is a great choice as well. Plus you are repurposing the clothes! ![]()
I wonder whether using a ‘screen cleaner’ product on laptop screens beats using water. For, 1) so doing will be safe, right? And 2) water can leave smudges.
I don’t think the risk of using a screen cleaner product is worth it. As for 2), I suggest using de-ionized or distilled water since that will not leave any smudges and is also much safer to be used around electronics.
Thanks! I will use one of those two types of water in the future.
I did in fact destroy a somewhat expensive monitor by . . spraying cleaning liquid directly onto it. The monitor might even have been turned on at the time. Still, I think I wanted to replace it anyway. But after that I have persisted in spraying screen-cleaner onto a cloth and then applying the cloth the monitor. I gather that cleaner that lacks alcohol and lacks ammonia is safe, or at least largely safe; I will err on the safe side by merely using water. I gather that distilled might be slightly more effective than ‘de-ionized’.
De-ionized water should be less conductive than distilled water. I think distilled water is mainly more sterile, which isn’t really important for screen cleaning. Either should be fine really, I would go for the type you can obtain more easily. De-ionized water for lead acid batteries is quite easy to come by here (and is very very cheap) so i use that.
Thanks.
What I managed to get was distilled water. But I am having trouble with it - and with a ‘screen cleaner’ by a company called ‘AF’. Let me explain.
The ‘screen cleaner’, together with the use of tap water, seemed to work alright for years. Yet, I find, now, that using either or both of (1) the Screen Cleaner, (2) distilled water, on clean-ish microfibre cloths, leaves smears and/or dirt on the screen. I do not know what is going on. Perhaps I am merely noticing gunk that previously I did not notice. Perhaps also my cloths are not clean enough, but I do clean the cloths somewhat regularly and I cannot be forever cleaning them. Arg! Nor is there any obvious source of the gunk.
If residue is being left behind (this sounds what is being described) then it is not being lifted off the screen by the fluid and captured by the fibers.
Cleaning cloths can actually break down a little over time, maybe try a new cloth (rip the tag off too, it scratches) and repeat or repeat with the existing cloths on hand and take a new microfiber and gently wipe just after cleaning and see if it lifts the residue off the screen.
Detailers frequently do this after washing a car and go back with a fine cloth over the same surface to pickup any light residue that may have been left behind when drying a surface.
If it is little bits of dust, it is attracted to the static on the dry microfibers and leaves a really clean surface behind.
Great stuff - thank you. I will try those suggestions, viz., use a new cloth, either entirely or as the last stage (and I’ll remove the tags).
One more thing, though. My cloth bag contains, as well as a slightly bobbled microfibre cloth, some smooth glasses cloths (enclosed within little plastic bags). Are those glasses cloths - though they are small - any good for using on monitors? Thanks!
Hey… we have cleaning recommendations in our KB on our site. Have you checked those out?
