Sil4
1
- Fedora 43
- Probably: Linux 6.17.7-300.fc43.x86_64
- BIOS: 03.05
- AMD Ryzen™ AI 300 Series (AI 9 HX 370)
Hi everyone, since I upgraded the BIOS I got a Booting Problem, could someone help me out?
“0.1317961 RDSEED32 is broken. Disabling the corresponding CPUID bit.
Warning: /dev/disk by-uuia/24eea343-1c5t-444f-bed3-4856449582/1 does not exist
Generating " run/initranfs/rdsosreport.txt"
Entering emergency mode. Exit the shell to continue.
Type “journalctl” to view system logs.
You might want to save “›un/initramfs/rdsosreport.txt” to a USB stick ar sboat after mounting them and attach it to a bug report.
Cannot open access to console, the root account is lacked.
See sulogin(8) man page for more details.
Press Enter to continue.”
thanks in advance!
Greetings Sil4
can you see your disk in BIOS? if not, then try to disable battery
Turn on laptop and spam f2 for 8 seconds
select “setup utility” → “advanced” → “Battery disconnect”
choose yes and confirm with enter
then save and exit (press F10 and then Enter)
turn of computer disconnect power cord wait 90 seconds
connect power cord, it should turn on and connect battery again, check if you can see drive.
Sil4
3
Oh thanks! Actually, I see my disk in the bios.
After trying to boot my desk I get that error message: 0.1317961 RDSEED32 is Broken. Disabling the corresponding CPUID bit.
After that, I get to my LUKS login, but I can not type. And after a while, I get the error message I have posted first.
Sil4
5
Wow, thank you, yes, that’s exactly how my boot process behaves. Have a nice night!
Greetings
Sil4
