Building a Two-Node AMD Strix Halo Cluster for LLMs with llama.cpp RPC (MiniMax-M2 & GLM 4.6)
I finally did it! I built a Llama.cpp two-node cluster with my Framework Desktop and HP G1a Mini: 256GB of Unified Memory to host large models like the new MiniMax-M2 and GLM 4.6!
In this video I go through the setup (incredibly easy) and the performance evaluation.
If only we can take time to add tensor parallelism on llama.cpp for multi-device config…
To minimize network throughput, it would be necessary to merge 2 matmul, therefore modifying the graph in a backend, and I’m not too sure what the right way to do it is.
For now make experiment with CPU and GPU with BF16 matmul backend…
Have you try to use the Thunderbolt Networking in place of the RJ45 port?
Will try - I didn’t do it for the video because I erroneously thought the HP mini did not have that. I now checked and it does, so I will try and see what the difference is, and update with the performance results.
For now with llama.cpp layered split it may have only a difference in loading time. But nice to know what we get.
I have to ask about the noise from the HP. Is it as loud as the reviews suggest? Or have they been a bit harsh on the fans at full spin?
The HP can get very noisy, it’s tucked away in a closet. the Framework is so quiet that it sits in my living room as a piece of decor!
When deliveries were uncertain I nearly bought one. Then read the reviews about the noise. Thanks for confirming … I feel better for having waited for the FW
