Buying framework in parts from the official store
Hello,
as of right now, the bundles of FW 13 with AMD Ryzen 7040 are out of stock. I was wondering if picking the DE chassis, wifi card, expansions and mainboard with this CPU would do the trick? Will it work or should I wait for re-stock? How does UK chassis is different from DE one?
Different keyboard.
Buying the individual parts will work, but will likely be more expensive.
There are reports that the chassis sometimes missed a few screws or other components that should be there, so be prepared to message support to get the missing parts.
Okay, thank you for your reply. I checked the prices and it turns out they are almost the same (at least for my currency - PLN). I’ll probably go with the ryzen 7840U :slight_smile:
