Can a 1240P be silent?
I am currently using an 6500U and - apart from when the processor is under proper load - the machine is generally quiet.
By quiet I mean no audible fan whatsoever, not just a quiet fan.
I had similar expectations for a 12500H I recently used, but unfortunately the machine was rarely not audible and most of the times - even without proper load - one could hear the fan, even if it was admittedly quiet.
Now, my question is, how does P behave? Does a, e.g., 1240P behave more like the 6500U and does not spin up the fans unless under proper load or is it more like the 12500H and you can usually hear the fan, even if rather quiet?
Would a 12xxU model be better in that case? Even if Framework does not offer it yet.
Thanks
This depends largely on the cooling design. However on the framework, its silent until it gets a heavy load. My fans only spin up while compiling code or slicing 3d models and sometimes when charging while the laptop is turned on.
By silent you mean silent, not even a quiet fan in the background, right?
Which is fair of course. Though, are you using the laptop mostly on battery?
Sure it can, it just depends on how much you are willing to tune the laptop. I am typing this up in bed right now and the fan isn’t turning at all. If you are willing to put in that time then it can be dead silent, especially if you are willing to go to extremes and limit performance. Hell, you can even disable cores and turn a P series into a U series.
@GhostLegion, I’d prefer not to have to tinker with half the system. Are you saying then it’s not too quiet out-of-the-box?
yes, at least as far as I can tell
I’d say it’s fine OOTB but the fan will spin. It depends on the OS used as well. I use Linux and I’ll admit that Windows is a better experience OOTB. The fan wasn’t screaming all the time or anything like that. You wanted dead-silent right? No fan spin? That will require some tuning regardless of OS, like setting custom fan curves.
Thank you, both.
Two a bit contradicting statements - @devryd, no noise - @GhostLegion, some noise
Depends on OS and workload. It might not be contradictory at all. Overall I don’t consider it a noisy laptop.
Of course, and I would expect the fan to spin when the load is higher, but as mentioned the 6500U is absolutely silent as long as one does Office-like tasks (including web browsing).
I am only wondering if I can expect the same with a P model, as it’s not the case with H. Or would only U provide that.
As for the operating system, let’s assume Windows.
Yeah, it’ll be silent
By silent, you mean silent silent, right?
And then I assume that was referring to above average load?
In that case the fans should actually spin :slight_smile: that’s their job, I just don’t want a whirring sound when I do regular Office-like tasks or regular web browsing
@user14
For the most basic tasks it should be silent. And if it isn’t silent enough OOTB, then it can be tuned. There is nothing else I can tell you.
I’ve been low-key waiting for a passive cooler for the framework motherboard, and kinda frankensteined one of my own for a small server build. A professional solution, even if it wasn’t fully passive, but instead used a low noise fan like the NF-R8 would be very nice. However, I don’t see way for something that even remotely fits the chassis or even the cooler-master cases.
