Problem
After updating from Firmware 03.05 to 03.07, without changing any bios setting, my charge limit of 50% is not respected, and the laptop will be charged to 100% when plugin power.
Fedora Silverblue/UBlue Derivative (SecureBlue, based on the latest version of UBlue silverblue-main)
Which release version?
OSTree status info are listed below (result of rpm-ostree status)
Deployments:
● ostree-image-signed:docker://ghcr.io/secureblue/silverblue-main-hardened:latest
Digest: sha256:058a2a27ace9f4fb953e8ed0aa586ee9860a1b314558646e6031e876d0d28c15
Version: 41.20250315.0 (2025-03-15T06:31:27Z)
LayeredPackages: ibus-table-mathwriter
Which kernel are you using?
$ uname -a
Linux cheng-fedora-framework-laptop 6.13.6-200.fc41.x86_64 #1 SMP PREEMPT_DYNAMIC Fri Mar 7 21:33:48 UTC 2025 x86_64 GNU/Linux
03.07
Which Framework Laptop 13 model are you using? (AMD Ryzen™ 7040 Series, Intel® Core™ Ultra Series 1, 13th Gen Intel® Core™ , 12th Gen Intel® Core™, 11th Gen Intel® Core™)
AMD 7040 Series
System Details Report
Report details
- Date generated: 2025-03-16 06:05:19
Hardware Information:
- Hardware Model: Framework Laptop 13 AMD Ryzen 7040Series
- Memory: 16.0 GiB
- Processor: AMD Ryzen™ 5 7640U w/ Radeon™ 760M Graphics × 12
- Graphics: AMD Radeon™ 760M
- Disk Capacity: 250.1 GB
Software Information:
- Firmware Version: 03.07
- OS Name: secureblue (powered by Fedora Atomic)
- OS Build: (null)
- OS Type: 64-bit
- GNOME Version: 47
- Windowing System: Wayland
- Kernel Version: Linux 6.13.6-200.fc41.x86_64
