Charging and sharing screen using the same USB C
Greetings, I got a question about how USB C works.
Can you use a USB C for charging and sharing media on a monitor at the same time?
For example the Gigabyte M32Q has a USB C and I want to know if it is possible.
Yes! USB-C is the physical port type so it doesn’t tell you much. But this laptop does support USB4, which allows that. It would just depend on what your other devices support.
