Dual USB-C Charging
I have a fairly power-hungry laptop I use for work. The laptop uses a lot of power and the dock I have for it actually uses 2 USB-C headers that are magnetically joined to deliver power to the laptop. I plugged my framework into the dual-header connector, and it charges and delivers video to my external monitors, but I am not sure if it takes power from both connectors (the charging light only lights up on one port).
I am guessing that since all 4 expansion ports can act as the charging interface for the computer, that there is a possibility of having multiple power sources for the laptop.
TRY:
Charging from multiple type-c ports - Framework Laptop DIY Edition - Framework Community
OR:
Does the framework laptop support charging via the 4 usb-c ports at the same time? - Expansion Cards - Framework Community
@DannyT thanks for that.
If anyone else stumbles on this thread, at this time, the laptop will only charge from a single USB-C port.
