Anyone know if there’s a chance to make a chromebook version of this? I feel like it could do better than their prior discontinued one since its cheaper and is a 2 in 1 touchscreen, which chromebooks can take advantage of more.
chrome os flex exists and can be installed on this, although official support is not guaranteed
I’ve never done it, but I bet you could install ChromeOS Flex without much difficulty. Odds are good that the touchscreen and tablet mode would work, although you’d have to try to find out
The major downside is that ChromeOS Flex doesn’t support Android apps (and is pretty locked down anyway). Usign an immutable linux distro with Waydroid sounds like a better choice, and I’ll do some experiments with that once my Framework 12 arrives. Maybe create a howto to set it up.
I find Waydroid to be a bit clunky really, hard to install and doesn’t integrate with the system very well.
