Did a fresh install of Fedora 43 on my Framework 16 then discovered the hibernate documentation and wanted to try it. However, I could not figure out how to delete the “/” partition with the Fedora 43 installation or how to manually create new partitions (i.e. boot and swap), and I’m not sure how to encrypt partitions using manually-defined mount points.
Has anyone successfully configured suspend-to-hibernate with Fedora 43? Thank you in advance!
Fedora 43, kernel 6.17 BIOS version 4.02 (I think) Framework 16 AMD Ryzen 7040
