Configuring LED Spacers and Keyboard colors on Arch Linux
So I have been curious on how I would get the ability to configure my keyboard RGB colors and LED spacers on my Framework 16. Been looking for advice, and guides on getting them to work are a bit scarce. This is for an Arch install (by the way).
For the LED spacer, I want to have it display battery charge info, and have that change color depending on if the laptop is charging or not.
What are you looking to do for the keyboard?
There are links to information and config tools here Framework | Using your Framework Laptop 16
keyboard.frame.work for the keyboard.
