This is pretty standard in coreboot, but isn’t perfect and has some issues.
Google uses VBOOT on their systems, it stores 3 copies of the firmware (RO, RW-A and RW-B). RO section is usually located in section of the flash chip that’s write-protected, and control over that pin is handled by CR50/Ti50 (H1 security chip).
It also uses TPM for measurment (you sign build with your keys and everything is checked before loading, providing a ROT that isn’t PSB or BootGuard).
This approach has issues, VBOOT doesn’t have stable ABI so if you flash coreboot 26.09 with VBOOT let’s say, and then you will want to flash 28.04 down the line, it will actually cause a brick.
Because of this, Google maintains their own fork of coreboot and backport upstream patches into their branch they tagged when device was released.
So while in theory it’s doable (I’m maintaining coreboot tree for large-scale industrial customer), you simply write new build with flashprog -p internal --fmap -i RW_SECTION_A -w build/coreboot.rom… but it won’t be that simple here.
PSP in these systems expect to find blobs at address 0x2000 (8KB) in the flash, plus I haven’t figured out ROM3 yet so only upper 16MB are currently usable.
Capsule updates from EDK2 are also mostly working from what I’ve been told, but I’m not tracking anything UEFI-related so I can’t comment on details.
On Intel side some people from 3mdeb and Tuxedo are experimenting with top-swap feature, I see that AMD has something similar (PSP A/B) but I haven’t looked at details yet. It would allow you to store two independent copies and overwrite one of them, having fallback recovery if anything goes wrong.
I find it a bit ironic that reliablity is still a problem in BIOS/UEFI world. This is why Gigabyte used to place two SPI chips on their boards and use custom feature in their ITE ECs to swap CS to a second chip if firmware hasn’t written an undocumented register over LPC to kill the “watchdog” within 3 seconds of asserting PS_ON.
Maybe they’re still doing that? Not sure, I haven’t been following the “enthusiast PC market” for over a decade now.
But… yes, coreboot is faaaaaar more reliable than UEFI regardless of the implementation (especially since I’m on the release team and test most platforms that we support before tagging the release). I haven’t had a single brick from simply doing an update in 5 years, on any systems I own/use on regular basis (~8 of them).
