Device connect/disconnect system sound recurring randomly and regularly
Which Linux distro are you using? – Fedora Linux 41 (Workstation Edition)
Which release version?
(If rolling release, last date updated?) – I check for an run updates daily.
Which kernel are you using? – Linux 6.13.9-200.fc41.x86_64
Which BIOS version are you using? – INSYDE Corp. version 03.04
Which Framework Laptop 13 model are you using? (AMD Ryzen™ 7040 Series, Intel® Core™ Ultra Series 1, 13th Gen Intel® Core™ , 12th Gen Intel® Core™, 11th Gen Intel® Core™)
– 12th Gen Intel Core i5
HERE IS THE ISSUE:
I have recently encountered a behavior from the device that has me stumped. A couple of days ago, the laptop started randomly and regularly playing the system sound that usually indicates the connection/disconnection or mounting/unmounting of a device, such as a USB thumb drive. I have tried rebooting with various peripherals disconnected, but the problem persists. Do you have any idea why the laptop would be continually making this sound?
That’s probably the sound that’s supposed to play when plugging in the power cable (or unplugging it), but there’s a recent Linux bug causes that sound to play when the battery starts/stops charging.
See Power charger repeatedly disconnects and reconnects in Fedora
Yes, all the symptoms seem to match. Thank you for the diagnosis! I perused the threads, and it appears that some power-management fixes soon will be pushed out to the distros, including Fedora. So, I think I’ll take the lazy (and not highly Linux-savvy) man’s approach and wait to see whether an upcoming update resolves the problem. Thanks, again, for helping me understand the cause.
Upower already knows and pushed the fix. Arch recently updated to upower 1.90.9 and my issues with the noises have stopped, so the fix is in the pipeline for sure.
This is the issue in the upower issue tracker:
Resolved a day ago. Not sure how long it usually takes for a fix like that to get released into Fedora’s packages
Fedora is pretty fast with updates. Probably a day or two. Although people might be busy with the imminent fedora 42 release.
