Display has visual glitches that won't appear when screen recording
Fedora
Which release version?
Fedora Linux 43
Which kernel are you using?
Kernel Version: 6.18.10-200.fc43.x86_64 (64-bit)
25.116.1
Which Framework Laptop 16 model are you using?
AMD Ryzen™ 7040 Series
My screen gets random visual glitches (Pixels quickly appearing and disappearing, typically when scrolling fast or watching video games). I’ve tried uninstalling my GPU (Although I didn’t have an expansion module to replace it with) and it still happened. And I tried uninstalling my display (From the display side not the mainboard side) but they still seem around
What kind of issue is this? How can I fix it?
does your laptop have dGPU or just iGPU? if your’s is still in warranty, it sounds like your iGPU/dGPU is about to give up and hopefully support will accept it on warranty.
it has both a DGPU and an iGPU
ah then, try uninstall dGPU and see if issue remain, if not then it is your dGPU having a issue and needs replacement.
I think I tried that? But I don’t have a regular expansion bay to replace it with so I’m not sure if any errors I saw there are a result of the iGPU glitching out or the fact that my computer literally was missing half the required components
what half of required components does it not have, that is missing?
Also since you got gen 1 it doesn’t have option i thought it would have, since Gen 2 has a option in bios where you can do both, dGPU only or iGPU Only. for graphics mode.
Well from what I can tell it’s missing both cooling equipment and it wasn’t able to get a wifi signal when I took out the graphics module.
Also is there a way to upgrade to gen 2 software or do I need to buy a new mainboard?
Ok, I booted up my computer with the interposer removed and the same glitches happened, if anything they seemed to be worse
you gota switch motherboard.
Sadly.
About your gpu issue if laptop used iGPU then it might be your iGPU giving up instead unless this is a issue with kernel?
Try booting up a another linux distro and see if same issue occurs.
Another alternative is to try Windows and see if you can get same graphic glitches, if it does not occur in windows but in linux, then it’s something todo with kernel in linux distro’s doing it.
I’ve reinstalled Fedora a few times. Thanks for the tips man.
These sorts of problems are a lot easier to understand with a video. Can you take a video with your phone and post that somewhere and link to the video here?
https://drive.google.com/file/d/1b4tWZ-gU6iiRbf26Dlxra_HJ1YL0Mpyk/view?usp=sharing Here you go
Try windows too just to see if it causes same graphic glitch.
I take fedora one as it didnt solve it?
I don’t have access to a windows copy. Just have Linux so far.
Fedora one?
You can download a windows copy from Microsoft google up media creator tool and make a iso or bootable usb directly and then install it without a license key and install the drivers package from framework and see if issue occurs in windows.
If it does not, then you can breathe out and confirm issue is kernel related in linux and not your dGPU or your iGPU flipping out.
About fedora I meant did you reinstall fedora and graphic glitch continued? If so try a different linux distro like kubuntu, ubuntu, zorin os etc.
Im using arch and have windows on a 1tb expansion. I get these same glitches when booted into Arch but not in windows. Pretty sure its some kind of video driver issue.
I’m getting the same visual glitches in arch linux (garuda, specifically) that don’t appear if I rollback to a snapshot pre-February 17th.
Running Plasma/kwin currently and the artifacts can be pretty significant at times but like OP don’t seem to appear with screen recording or sharing (discord, in my case).
I still have the pacman logs if anyone is curious; there were numerous kde & plasma related updates including one for wayland and I’m betting one is the cultprit.
_om
Based on the pattern of the glitches. I don’t think it is a display problem.
I think it is most likely GPU software/driver bugs.
Probably best to report them to AMD.
I have a FW16 AMD 7840HS and have not seen these sorts of glitches.
Do you have a dGPU as well as the iGPU ?
I do, I use both
Do you have a way to roll back?
If this turns out to be purely software side and I just bought new hardware for new reason won’t there be egg on my face lol
