Hi All,
I have a 7040 series with the 2.8k display running Win 11 and BIOS 3.09. I noticed after I updated to drivers to v2.05 that my screen brightness could not change and my display out was not working.
The laptop screen brightness slider has disappeared from settings and while I can change the slider with the fn keys the screen does not change (i.e., 0% looks the same as 100% brightness).
I usually have two monitors connected via hdmi to a usb-c dock. Both do not recognize the laptop through the usb-c dock or hdmi port on my laptop (I have my ports around to check ports).
Has anyone been experiencing this issue? Hopefully there’s an easy fix I am overlooking.
Thanks peeps!
