Display refresh rate not returning to previous setting when switching from GPU to APU
So I have encountered an issue that I haven’t seen anyone else talking about so I figured I’d make a post to see if anyone else is experiencing the same thing and if there’s any way to fix it. When the laptop is using the 780M iGPU, there are five options for refresh rate in Windows settings: 165Hz, 82.5Hz, 60Hz, Dynamic (83 or 165Hz), and Dynamic (60 or 120Hz). I would prefer to use the Dynamic (83 or 165Hz) mode for power efficiency reasons without giving up too much in terms of display smoothness. The problem, however, occurs when I open a program that switches to the RX 7700S dGPU. When using the dGPU, there are only two refresh rate options: 165Hz or 60Hz. This would normally be fine as I only really want to use the dGPU when plugged in, so having the display at it’s max refresh rate is fine. However, when I close the program and it switches back to the 780M, the display keeps the 165Hz setting instead of going back to the dynamic mode I had previously selected. While it’s not a super serious issue, it is definitely an annoyance having to remember to open the display settings and set the refresh rate back to dynamic. I’m not sure if this is a Windows issue, a driver issue, or something else, but hopefully someone smarter than me maybe knows why this is happening and how to fix it. Thanks everyone!
Hi, surprised to see no replies here yet. I’ve been fighting with this issue on and off since I got my batch 1. I’ve tried the Framework-supplied drivers, as well as full, minimal, and driver-only installs from AMD’s webpage. All of them had the issue, and I’ve also had some similar problems with AMD Smartshift Eco turning itself off after awhile. It’s a crying shame because the balance between power on A/C and efficiency on battery was one of the main reasons I got this laptop, but the software doesn’t seem quite there yet.
I have had a similar issue, where my batch 20 fw16 win11/24H2(26100.3194) would refuse to fully switch the display to the gpu and smartshift will get deactivated every time i close a application that it thinks is a game. Updating all drivers to 24.12.1 has improved it a bit. Now it will refuse to switch the display to the gpu only on battery, but manually assigning in windows settings will still use the gpu for calculation, but not switch to it on battery. Plugged in it behaves properly. Smart access wont get disabled anymore, but it has no affect now, it just behaves like it is always enabled on battery, but plugged in it behaves properly. Dynamic refresh rate seems to work correctly now tho. Also it seems to unlock overclocking on the cpu, but i havent tryed it yet since i am also affected by the bad thermal interface issue and havent fixed it yet.
EDIT: WARNING! i just found out that it limits the total power-consumption to 20w. That means the driver version 24.12.1 is bugged and unuesable. very sad indeed
