I previously had my DisplayPort expansion card plugged into the bottom left expansion port, and it worked fine except that after an hour or so or after going to s2idle sleep, it wouldn’t come back on. Nothing would restore it, unplugging the cable or the expansion card. Only fix was to shut down the laptop and start it back up.
Snippet from dmesg:
[ 3997.015745] usb usb2-port3: Cannot enable. Maybe the USB cable is bad?
[ 4001.087740] usb usb2-port3: Cannot enable. Maybe the USB cable is bad?
Today it happened again, but I tried moving the expansion card with DisplayPort cable attached to a bay on the right side of the laptop, and it started working again.
The expansion card that I swapped in for the original DisplayPort location was a USB-C card which is working with power and data.
Has anyone else noticed this behavior?
I’m running Arch Linux with kernel 5.14.8-zen1-1-zen with the DIY i7-1165G7 edition.
