Plugable TBT4-UD5 Dock
Working:
- USB-C PD
- USB-A downstream ports
- USB-C downstream ports
- RTL8153 USB Ethernet (2.5GbaseT)
- HDMI port 1 (only when connected to port 2 on FW16; does not work properly when connected to port 1 on FW16)
Tested with:
- Debian Testing (kernel 6.7.12-1, amdgpu firmware 20240410, KDE Plasma 5)
- Ubuntu 24.04 (kernel and firmware as provided in installer, KDE Plasma 5)
- LG 34UC88-B display
- LG 27UK500 display
HDMI behavior when connected to FW16 port 1 (USB4/TB4) is quite strange (and both displays work fine when connected directly to FW16 using an HDMI expansion card) - sometimes the display will be detected, but with only 640x480 resolution available; other times the laptop locks up and has to be power cycled when the display is attached to the dock. The display works fine when connected to FW16 port 2 (USB3.2).
If you can reproduce using the latest kernel (6.9-rc7) please post a bug to Issues · drm / amd · GitLab with logs and more details.
Just updated the post: I’m not sure why I didn’t test this before, but the display works fine when connected to port 2 on the FW16.
I just got the TBT4-UD5 and have the same problem with an LG34" display. So glad I found this, I had the USB-C module in port 1, switched to 2 and it works fine now. I’m using Fedora 40, but don’t have the latest kernel RC installed though. Thanks for posting this!
I’m having dock issues as well.
I have the discrete GPU module and when connected to a TB4 dock with two Display port monitors connected to the dock the computer only sees one of them. Oddly, if I restart it randomly chooses which monitor to use so I know the dock isn’t an issue.
I tried two different docks. One is the HP USB C G5 essentials dock and the other is the Razer TB4 dock.
With this said, if I connect to a USB C module in Port 4 both displays are able to be used along with the built in display.
So long story short I fixed it by not connecting directly to the USB C on the Graphics module but it still bothers me that I can’t figure out why connecting there doesn’t allow for more than one monitor and the built in display.
I’ve got the Debian 6.9.7 kernel installed now and the behavior hasn’t changed; port 1 still produces a 640x480 display with no options to change it.
