Docking station not fully working
Ubuntu 24.04.3
Which kernel are you using?
6.14.0-29-generic
Vendor: INSYDE Corp.
Version: 03.05
Which Framework Laptop 16 model are you using? (AMD Ryzen™ 7040 Series)?
I’ve gotten a Lenova Thinkpad Hybrid USB-C with USB-A dock. And I got it to work except for charging. The most likely reason is that only USB ports 5-6 seem to allow the dock to connect, but those ports don’t have charging capabilities. In ports 1-4 I constantly get the follow errors when checking through dmsg:
So the issue seem to be that something is different for ports 1-4 to such a level that the dock isn’t recognized at all. I just can’t figure out what and how to fix it. Anyone have any ideas?
I checked with coworkers that have Framework 13s and they don’t have this issue at all.
Correction ports 1-2 and 4-5 aren’t working. 3 and 6 everything except charging works. Every other non framework and the framework 13 laptop work as intended. So there is something different about just those 4 usb ports.
I have a similar dock that works fine. I usually plug it to port 4. Are you using USB-C or A to connect it?
Have you tried using a different cable? Maybe signal integrity is not good enough.
It is possible to update the dock through Lenovo Vantage. Have you tried that?
I am on Ubuntu. So vantage is not an option. USB-A would not charge the PC as that doesn’t have that ability. And we just bought a ton of these docks, they do charge on all the other Linux machines but not on the Framework 16s.
Is there no other Windows PC available to run the update?
windows 2 go to the rescue?
